Throwout bearing?
Old Aug 8, 2004 | 02:52 PM
97Transam123's Avatar
Throwout bearing?
I am really not sure if i am suppose to be worrying about this or not.
I have a 6 speed transmision. T-56
But when i put it in nuetral and pull the e brake and let it idle. If i bend down by the driver's side door i can hear a rumbling noise. like metal fitting loosly on somthing else. or a bad bearing... i am not sure if anyone has had the same problem like this but if u need more input just ask ill be checking this alot
Old Aug 8, 2004 | 03:05 PM
ZDriver96's Avatar
Re: Throwout bearing?
Mine does that.. the ticking kinda noise isnt very loud.. Ive replaced it and it still does it... Infact I replaced the entire clutch and tranny setup and it still does it slightly...
It did not do it with an LT1 t/o bearing.. but with the 2 LT4 t/o bearings it has.. and i currently run the lt4 clutch.. It has been no problem for me mechanically.. car runs fine.
Old Aug 8, 2004 | 03:09 PM
PANZ28's Avatar
My 97's stock clutch did that also. I assume it was the throwout bearing. Never had any mechanical issues, just annoying.
Old Aug 8, 2004 | 03:57 PM
Yeah i dont really notice any mechanical problems with the car it shifts fine and everything so i guess ill just look twords my exhaust leak issue and nont worry about that as much
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
