Throw out bearing and input bearing?
Old Apr 28, 2003 | 09:20 AM
tryme96Z's Avatar
Im replacing my clutch and I was told I should replace the throwout bearing(or course) and the input bearing(not really sure what bearing this is). Are there any special aftermarket throwout bearings or input bearings? IE any stronger than stock. Im just really not sure what exactly I need. Also I have heard its a good idea to replace the main seal. How hard is it to replace the main seal?
Old Apr 28, 2003 | 09:44 AM
mike95z28
Guest
Posts: n/a
The only two bearings there are the pilot bushing/bearing and throwout bearing. If you replace your pressure plate, the PP usually comes with a brand new throwout bearing. If you plan on reusing your PP, order a stock throwout bearing. It's a 5 second replacement when the PP is off (seriously). As for the pilot bushing/bearing, get the solid brass bushing. Not the easiest to replace but definitely the best replacement over the needle or roller bearing (both of which have issues w/ breaking).
Input bearing? No clue.. sounds like someone got that term confused w/ the pilot bushing.
Hope that info helps.
Old Apr 29, 2003 | 08:03 AM
tryme96Z's Avatar
Know any good place to get a solid brass bushing?
Also anyone know much about the rear main seal? Im guessing its the pressed seal that is about 3-4" inches in diameter that seals to the crank it looks like. Is it worth replacing and once again know of a good place to get one(something tells me the dealer will guoge(sp?) me for it)?
Old Apr 29, 2003 | 08:16 AM
mc63's Avatar
If the rear seal is not leaking, do not replace it.
You should replace the pilot bushing/bearing.
It is located in the "hole" in the middle of the crank/ flywheel.
I used a 3/8" round rachet handle. It's a little small so I wrapped it with electrical tape to fit snug.
Put some grease in the hole first and insert the handle, bump the end with your hand. As it starts slidding out, you will have to add more grease. Keep doing this, it will eventually pop out.
Good Luck,
Michael
Old Apr 29, 2003 | 09:11 AM
QUASARBLUEZ28's Avatar
Jegs has pilot bushing for 7.95. Handleing is more than the bushing. Summit has one for 2.95 (zoom) and another for 7.95 as well.
Old Apr 29, 2003 | 09:45 AM
tryme96Z's Avatar
Good Luck,
Michael
I think it does leak. At the bottom of the bellhouse/the black plate that makes with the bellhouseing was pretty oily.
Old Apr 29, 2003 | 10:43 AM
94 CAMRO Z28's Avatar
Anyone have part #s for these bearings and the seal? Im going through the same process right now.
Aaron
Old Apr 29, 2003 | 01:46 PM
tryme96Z's Avatar
From Summit(havent checked shipping yet):
Pilot Bronze Bushing All Chevy Stock Replacement
LAK-15976
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
whitehooptie
Aug 10, 2015 07:02 AM
Z28-50
Aug 7, 2015 01:22 AM
zajones
Jul 30, 2015 02:18 PM
