Throttle Stop/TB questions
Old Feb 4, 2004 | 04:25 PM
Fastbird93's Avatar
Just wondering, in looking at my TB, I noticed that with the throttle closed, I've still got a visually noticable gap, I.E. the blades aren't closing all the way.
Approximately how much gap should there be on a properly adjusted throttle stop??
It's a BBK 58 MM also.
Speaking of, does anyone know is there's a common problem with IAC passaged on the BBK tb's???
Old Feb 4, 2004 | 04:33 PM
Kain's Avatar
The only way to tell is by putting it on your car. If it idles high, close the blades up a bit with the screw until the IAC has to do its job to regulate idle.
Old Feb 4, 2004 | 04:35 PM
Fastbird93's Avatar
well, I'll play with it tonight.
Can I make the adjustment at idle possibly??
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Form
Feb 10, 2015 11:23 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
