Throttle sensor 4.8 or 4.9 on WOT
Old Jun 28, 2008 | 06:26 PM
detroit1994z28's Avatar
I have a 94 camaro z28. I been having problems with a code which is DTC 21 - High voltage throttle sensor. It's currently reading .62 idle and 4.9 WOT. I heard on the 94 models it should not exceed 4.9 on WOT. I also heard it should not exceed 4.8 on WOT. I just basically want to know where to set the sensor at. Should it be at 4.8 or 4.9 on WOT?
Old Jun 28, 2008 | 06:38 PM
Either should be fine. The PCM uses a 5v reference, so it can't be more than that.
Old Jun 29, 2008 | 11:14 AM
I have a manual page, but it doesn't specify the year.... might be for a 93.
Code 21 will set if:
-signal voltage is greater than 2.5V
-engine is running
-air flow is less than 15 Gram/sec
-all conditions met for 3 seconds
OR
TPS signal voltage over 4.5V with ignition on.
Not sure if this applies to your 94, but the point is to show that there is more than one diagnostic test run on TPS.
I also have the 96/97 charts, and that indicates that the OBD-II system simply check for voltage exceeding 4.9V for more than 1 second while the ignition is on, to set the code. But they changed a few things between OBD-I and OBD-II diagnostics. Best thing would be to ask if anyone has a 1994 manual, and can look up the diagnostic criteria for you.
Did you ever turn the ignition to "on", hook up a volt meter to the blue signal wire/black ground wire and slowly rotate the throttle blades, looking for "spikes" in the voltage?
Have you verified that the reference voltage (gray wire) is not excessive, and above 5.0V?
Old Jun 29, 2008 | 12:53 PM
The 94 manual says DTC 21 will set when:
TPS signal is greater than 2.5v, engine idling (less than 10 grams/sec air flow), all conditions met for 5 seconds or TPS voltage over 4.8v with ignition ON.
So, WOT is not the only concern. The TPS should also be checked for a linear progression from throttle closed to WOT (engine does not have to be running for you to do this).
Old Jun 29, 2008 | 02:43 PM
Z28LT1_Just_Nasty's Avatar
If you have access to an oscilloscope that would be your best tool for checking out that TPS. Regular multi-meters/volt-meters typically cannot refresh the data fast enough to pick up every area of the signal so you may miss a possible problem section.
HectorM52
Jul 30, 2017 11:46 AM
mightymouse383
Jul 20, 2016 07:34 AM
captcorvette
Mar 7, 2015 12:37 PM
Queens94z28
Dec 20, 2014 09:11 PM
TrouserSnake
Jul 22, 2002 06:53 PM
