throttle positioning sensor
Old Oct 23, 2007 | 05:24 PM
Texas_96_Z's Avatar
I just bought an AC Delco IAC motor and I was thinking about just replacing the TPS also with an AC Delco unit while I'm in there. Is there any special trick to replacing the TPS or do you just swap it out for the new one?
Old Oct 23, 2007 | 05:25 PM
blueformula350's Avatar
Its just plug and play.
Old Oct 23, 2007 | 05:26 PM
dangalla's Avatar
i have always been a firm believer of " if it aint broke, dont fix it" but yeah you can just replace it
Old Oct 23, 2007 | 05:27 PM
Welllllll...... to change the TPS sensor, you would remove the two screws and take the old one off the side of the throttle body. Then make sure the seal was still in the hole in the TB, insert the new TPS sensor, jiggling it slightly to make sure the shaft is correctly indexed in the slot, rotate is slightly so the holes in the sensor line up with the holes in the TB, and put the two screws back in.
Old Oct 23, 2007 | 06:39 PM
WS6T3RROR's Avatar
Injuneer what exactly is the purpose of the tps "seal" my car i guess never had one since i've had it, and still doesnt have one.
Old Oct 23, 2007 | 06:56 PM
dangalla's Avatar
it keeps unmetered air out of your motor, a leaking seal would be a vacuum leak
Old Oct 23, 2007 | 07:09 PM
WS6T3RROR's Avatar
a vacuum leak through the throttle shaft? that doesnt make much sense cause the tps only covers about 60% of the opening. guess i could try a little experiment with that to verify it.
Old Oct 24, 2007 | 07:19 PM
Texas_96_Z's Avatar
thx for replies
Old Oct 24, 2007 | 08:44 PM
ChevalierSS's Avatar
Why replace it? It is a very simple reliable "mechanical" sensor. For whatever reason it does fail, it won't leave you stranded and is easy to replace.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Queens94z28
Dec 20, 2014 09:11 PM
