Throttle Cables
Throttle Cables
I decided that a good project for a few days would be to polish some stuff under my hood. I am removing the throttle body, and have it almost out, i just cant seem to get the throttle cable off. Not the bigger one. The little one that is on the outside, does the clip just pop off the tb. I dont want to butcher it up. Thanks in advance
You are probably referring to the cruise cable. If you wiggle and pull to the side, you will probably break it. Push it forward to remove it.
Aug 24, 2015 06:41 AM
detroitmuscle
Jul 31, 2015 04:21 AM
88IROC_Z
Jul 22, 2015 11:38 PM
