Is this throttle body stock????
Old Feb 20, 2004 | 09:58 PM
ChevyTuffD.A.'s Avatar
I have the throttle body off my car and it looks like it would be stock. But what i question is that it is stamped "MPFI Rochester Products" It doesnt say GM anywhere on it. Is that normal? Do they all say that?? I am not sure how to measure the throttle body but i measured one of the butterflys end to end and it was right at about 58mm. I am pretty sure its stock but does anyone have any input???
Old Feb 20, 2004 | 10:10 PM
Prorac1's Avatar
Yep, stock, rochester (makers of the infamous quadrajet) has been making fuel components for GM for over 30 years. Hope this helps, Prorac1
Old Feb 20, 2004 | 10:23 PM
Yea that helps, cant say i am really dissapointed, i hear they dont do much anyway. But how do you go about measuring a throttle body?
Old Feb 20, 2004 | 11:34 PM
Like since the 50's or maybe earlier.
Are you sure you did not measure 48mm? I think that is the stock size.
Old Feb 20, 2004 | 11:39 PM
Where does is say that? My stocker just has the part #'s on it, and "Made in USA".
You measure the inside diameter of each individual bore, where it connects to the intake manifold - that would be the same as the blade diameter. 48mm. If you measured the height of the oval that the bellows attaches to, you might get about 58-60mm, but that's not the "size".
Old Feb 21, 2004 | 12:27 AM
IrocManiac's Avatar
48mm is stock...injuneer is correct you measure the inside diameter.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
