Throttle body size
Old Oct 23, 2010 | 11:51 AM
fitz796's Avatar
Throttle body size
I just got a 58mm ported intake manifold for my 95 z28. Before I put it in this weekend I plan on getting a ported throttle body aswell. I can obviously put in put in a ported throttle body up to 58mm that will work with the intake manifold, but I was wondering if I should even consider a 52 or 54mm one instead?
Old Oct 23, 2010 | 12:17 PM
Ricardo's Avatar
If you dont have any additional mods just use the stock throttle body.
If you have ported heads, cam and headers then you should also consider a bigger TB.
Old Oct 23, 2010 | 12:36 PM
fitz796's Avatar
thanks for the feedback. good to know
Old Oct 23, 2010 | 02:31 PM
96capricemgr's Avatar
Also be aware a bigger TB without retuning a A4 car for it will do transmission damage over time.
I would not bother swapping the intake.
Old Oct 23, 2010 | 02:48 PM
fitz796's Avatar
Sorry for the stupidity but a4?
Old Oct 23, 2010 | 07:18 PM
4-speed automatic transmission = A4. In 93, a 4L60, 94-02 a 4L60E
Old Oct 24, 2010 | 08:06 AM
95Blackhawk's Avatar
Also be aware aftermarket TB's are commonly designed to dump idle air into the main plenum instead of the Idle Air Plenum passages GM designed in our intakes. This screws up your idle. I would be prepared to tune if you want it acting like stock again.
Old Oct 24, 2010 | 04:14 PM
fitz796's Avatar
well im not sure if makes a difference but mine is a 6 speed....not automatic
Old Oct 24, 2010 | 05:32 PM
The A4 is shifted by the PCM, based on throttle position, etc. If you alter the throttle body, you alter air flow vs. throttle position, and that throws the shifting off, requiring a reprogram. This is not an issue with the M6 (6-speed manual).
Might want to add a "signature" with basic info about your car - year, model, engine, trans and any major mods. That makes it easier for people to help you.
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jul 4, 2005 05:00 PM
