Throttle body questions...
Old Mar 9, 2004 | 08:22 AM
Hawk350's Avatar
What is the difference between 58mm BBK throttle body ($350) or 58mm holley ($400+)? I mean a 58mm is 58mm right? So whats up with the price diff???
Old Mar 9, 2004 | 08:27 AM
Hawk350's Avatar
Will the 58mm will be ok for heads and cam or too much?
Old Mar 9, 2004 | 08:43 AM
gamecockfan04's Avatar
The stock 48mm TB is fine unless you port the intake.
Old Mar 9, 2004 | 08:55 AM
badblackta's Avatar
The Holley is shiny
Old Mar 9, 2004 | 08:56 AM
Hawk350's Avatar
I am porting the intake.....I have been told by my engine builder that the 48mm is good for about 415 crank hp.....I am looking to put down about that at the wheels......so I think the 48mm wont suffice.
Old Mar 9, 2004 | 09:01 AM
OK. If youre porting the intake 52mm or 58mm will work fine. Basically the price difference is the Brand and metal type their made from, but either brand will work fine.
Old Mar 9, 2004 | 09:06 AM
Hawk350's Avatar
Thats all I needed to know By porting the intake, how much more hp will that make? Also going with a custom cam...227-230 range...
Old Mar 9, 2004 | 09:10 AM
That should probably add close to 30 to 40hp
Old Mar 9, 2004 | 09:19 AM
Hawk350's Avatar
Thats more than I have anticipated....with fully ported heads, intake, and a 230/236 cam....can I anticipate 400rwhp or more? Also changing injectors to 32lbers
Old Mar 9, 2004 | 09:20 AM
How much rwhp do you currently have?
Old Mar 9, 2004 | 11:26 AM
Hawk350's Avatar
Currently with my mods...310 maybe.....
Old Mar 9, 2004 | 11:45 AM
With all of that which you are having done and if you get some 1.6rr and a CAI you could probably get close to 350-360rwhp. I really dont know much about the 230/236 cam, but based off of similar cams I think thats a good estimate. I also believe with the 230/236 youre going to need to get your comp reprogrammed. Good Luck!
Old Mar 9, 2004 | 12:27 PM
BUBBA's Avatar
AS&M 54MM
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
