throttle body question?
Old Apr 24, 2006 | 01:26 PM
robwin95z's Avatar
is the twin 58mm TB the biggest for the LT1? can yall recommend what i should go with when upgrading this part? are air foils needed on aftermarket TB'S?
here's what i currently installed if it helps yall picking out the best TB:
pacesetter longtubes
ORY
SLP loudmouth
Old Apr 24, 2006 | 01:28 PM
Javier97Z28's Avatar
Moderator
Re: throttle body question?
Your stock throttle body is enough for your current mods, waste of money for little to no gain at this point.
Stick the money in gears or something along those lines.
Old Apr 24, 2006 | 01:50 PM
robwin95z's Avatar
sorry, along with the TB, i was wanting to add the following:
SLP CAI
Trick Flow Intake Elbow
would you recommend the TB only when i start getting ready for a heads/cam upgrade?
Old Apr 24, 2006 | 01:59 PM
Moderator
correct!
Old Apr 24, 2006 | 03:43 PM
If the twin 58mm TB isn't big enough, there's a "monoblade" that's even larger. A 52mm will take you to 500 flywheel HP, based on my dyno testing. Listen to Javier.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
