throttle body question
Old May 23, 2005 | 10:52 AM
tkiely05's Avatar
I'm installing a 236/242 cc xe grind cam soon and I was wondering will getting a bigger throttle body make a difference.
Old May 24, 2005 | 03:18 PM
magnumv8's Avatar
Re: throttle body question
any gains would be minimal with your mods. You would probably be better off spending the $$ on something else.
Old May 24, 2005 | 04:48 PM
taguy001's Avatar
It's not worth it, you'd probably see between 0-3 hp. I've seen people go to 52mm throttle bodies and gain nothing on bolt on cars, with a cam it might pick up a few.
Old May 24, 2005 | 05:41 PM
Alpinetypers's Avatar
What about if you do Port Matching also???
Old May 24, 2005 | 05:56 PM
RamAir95TA's Avatar
Port matching what? A 52mm throttle body will bolt to the manifold just fine without problem. The 58mm requires the intake holes to be enlarged.
Old May 24, 2005 | 06:07 PM
I was at the Mechanics shop that has my engine and they were telling me they were port matching the heads and intake. They take the new gasket and trace around the inside and grind the extra metal out to increase intake size. That is what I picked up from it, seemed logical to me.
Old May 24, 2005 | 06:33 PM
tkiely05's Avatar
I didnt mention that I am also installing long tubes and of course 1.6 roller rockers. i dont know if it makes a difference but any feedback is appreciated.
Old May 24, 2005 | 06:38 PM
tkiely05's Avatar
thanks ramair95ta ive been looking for a sound clip of the cam. what else do you have done to the car?
Old May 24, 2005 | 06:56 PM
taguy001's Avatar
The port matching the builder is referring to is in the intake ports, not the part where the throttle body mounts up. You don't really need a bigger throttle body unless you're forced induction or have a full built motor ie 383.....
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
