Throttle body leaking oil?
Old Sep 18, 2007 | 06:04 PM
Craddock's Avatar
Since I came to college, my car doesn't see the same amount of miles it use to, but when I do drive, I drive usually 180-200 miles a trip. Anyway, I don't know if it's where I use to drive like 40 miles one way and now I'm doing 200 or what but I'm leaking oil a lot more than I use to. So I opened the hood to put in some oil, and basically the whole top of the throttle body is covered in what I'm thinking is oil. I put in an airfoil a while ago and saw that I needed a new gasket for the top of it, but Advance didn't have one, so I put it off. Now I need one, so where would I get it? If it's a dealer product only, if someone could get me the part number I'll just order it.
Old Sep 18, 2007 | 06:08 PM
dangalla's Avatar
there is no oil that flows through the throttle body, it has to be coming from somewhere else
Old Sep 18, 2007 | 06:09 PM
Craddock's Avatar
Whatever it is, I still need the number for that gasket, I'm not too worried about the oil right now cause I won't be home till the weekend and I can't work on it till then.
Old Sep 18, 2007 | 06:11 PM
dangalla's Avatar
you can check shoebox's site
www.shbox.com
Old Sep 18, 2007 | 06:12 PM
Craddock's Avatar
Found it, I don't know why I didn't look there first, sorry.
Old Sep 18, 2007 | 06:13 PM
The Engineer's Avatar
Possibly the PCV fresh air inlet tube from the passenger valve cover is "reverse flowing" due to crankcase pressure and causing the oil in that area.
WD
Old Sep 18, 2007 | 08:56 PM
Craddock's Avatar
WD
What could I do about that?
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
