Throttle Body Disassembly
Old Jul 19, 2004 | 01:00 AM
Poik's Avatar
Tomorrow I will be putting my car up and taking the calipers off and giving them to my friend to sandblast while I install my LCAs. Then I am going to powdercoat the calipers, and then if I have any more time I want to do the throttle body. So here is my question: Is it just 4 bolts to take off and put back on? Is there a seal I would need to replace or anything of that nature?
Old Jul 19, 2004 | 01:19 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
Re: Throttle Body Disassembly
yes its just the 4 bolts. there are other things to remove, intake air, oil vent from valve cover, engine coolant lines, TPS wiring, and yes there is a gasket between your throttle body and intake manifold. i also replaced the gasket on top between the TB and the cover plate. - david
Potent77
Mar 16, 2022 12:13 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
