Beehive springs
Old Jul 19, 2004 | 02:12 AM
disco192's Avatar
Beehive springs
So ive been looking into some new springs. I just got a new set of Lloyd heads with 612 springs and im toying with the idea of beehive springs. I have a 306 cam and i want to spin to 7k rpm. My valvetrain is ready to handle it, but im not sure about the springs. Beehive springs look like a good alternative to double springs and TI retainers which gets expensive real fast.
Anyone have/like beehive springs for LT1s ? Where is a good place to find these?
Thanks,
Stu
Old Jul 19, 2004 | 02:21 AM
formula383's Avatar
Re: Beehive springs
I have seen a few people on here using them and they seem to be happy with them. Get in touch with Bret Bauer (SStrokerAce) he really likes them and I'm sure that he could hook you up with a set.
Old Jul 19, 2004 | 04:47 AM
Amped96's Avatar
Re: Beehive springs
My buddy is installing a set (comp 918s) right now into his 93 Formula along with a cc306. My roommate who works the comp cams tech line recommended them to him. I plan on going with a custom XE grind that he has recommended and he recommended the 918s for me also.
Old Jul 19, 2004 | 08:58 AM
truedualws6's Avatar
Re: Beehive springs
I would also suggest that you get in touch with Bret Bauer (SStrokerAce).
He can also recommend a valve spring seat that will work, especially if you
still have stock valve spring pockets.
I have the 26915s installed and they seem to be working great. I used the
Comp 795-16 retainers, 614-16 (+.050) locks and a .062" thick spring seat.
My installed height was 1.745" which will be good for .600" lift with a .060"
safety margin. Also do a search on the word "beehive" and you will find lots
of information.
Old Jul 19, 2004 | 11:37 AM
DrewHMS97SS's Avatar
Re: Beehive springs
beehives are bad ***. the shape makes the valve angle opening and closing straighter than a normal style spring. beehives will allow for some impresive lift too.
Old Jul 19, 2004 | 12:43 PM
disco192's Avatar
Re: Beehive springs
would the 26918s be able to handle 7k rpm with a cc306? what is the deal with the spring seat? Will the stock seat work for these?
Old Jul 19, 2004 | 01:24 PM
Re: Beehive springs
the stock seat works with these springs. you should not have any problems reving that high with the 306 cam.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
