Throttle Body Bypass Kit?
Old May 31, 2004 | 02:57 PM
Robert_K's Avatar
I was wondering if was hard to make your own throttle body bypass kit? Is it as simply as buying a coolant hose matching the entry and exit hoses of the throttle body, then connecting them, or do I need to do other things involving electrical sensors etc. How simple is this?
Old May 31, 2004 | 03:30 PM
joeSS97's Avatar
Do it yourself.All you need is a 3/8 double hose barb connector.Simply connect the two lines together.
Old May 31, 2004 | 05:22 PM
n2ceptor's Avatar
plus acouple of hose clamps..... Cost about 3 bucks...
Old May 31, 2004 | 06:46 PM
mvnatedog's Avatar
I did it with a little piece of 3/8" diameter copper tubing I got from the hardware store, plus two hose clamps... Total cost: <$3
Old May 31, 2004 | 07:33 PM
Robert_K's Avatar
Thanks for the advise!
Old Jun 20, 2004 | 10:55 AM
orbitalshock2k's Avatar
Does anyone have a website that tells you step by step how to do this, w/ pictures preferably?
Old Jun 20, 2004 | 11:42 AM
n2ceptor's Avatar
I dont have pics, but if you look at the thottle body with the rubber elbow removed, you will see 3/8 lines on the left and right sides that connect near the bottom... Those lines have radiator fluid flowing though the bottom section of the thottle body... Its to allow the air to warm up and help with emissions, and some people say cold starts..
Just remove the two line, be careful there is fluid in them, use a rag under the TB before disconnecting... And use the parts listed earlier, connecting the lines together..... This allows for the air to remain alittle cooler entering the intake.... Hence alittle more power....
Hope this helps....
Old Jun 20, 2004 | 12:07 PM
Ya I found the page, thanks for giving me the warning about the fluids. I'll probably do this later
Old Jun 20, 2004 | 12:19 PM
dabez1's Avatar
TB bypass
I used this one, it was really helpfull.
Old Jun 20, 2004 | 12:23 PM
93s and 94s need the coupler, 95-97s do not. Just do it like this. Very simple.
Old Jun 20, 2004 | 01:11 PM
Chuckman93's Avatar
Will there be any coolant left in the throtle body and how do you get it out?
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
RedLineRev
Jan 23, 2003 03:51 PM
