throttle body bypass
Old Feb 28, 2005 | 02:42 PM
Irocdriver89's Avatar
throttle body question when i unplug the coolant line from the radiator do i need to plug the pipe on the throttle body also when i disconnect the 90 degree hose that goes to the side of the throttle do i need to plug it already hooked the hose from the radiator to the piping from the block don't know if these would be vaccum leaks
Old Feb 28, 2005 | 02:49 PM
OBE1 95Z28's Avatar
Re: throttle body bypass
No vacuum leaks...remember coolant flowed through these passages. I put some rubber caps on my to keep the spiders out
Old Feb 28, 2005 | 03:17 PM
americanmusscle's Avatar
http://shbox.com/1/tb_bypass.jpg
Brought to you by shoebox. Just cap the throttle body passage. You will be fine.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
warmeck
May 1, 2015 11:30 AM
RedLineRev
Jan 23, 2003 03:51 PM
