throttle body
Old Mar 7, 2004 | 04:15 PM
ScottZLT1's Avatar
throttle body
I have a used throttle body and it is leaking coolent and the car shifts hard and it takes a really long time for it to shift why would this be please someone help!!!!
Old Mar 7, 2004 | 05:46 PM
Coolant flows through a plate that bolts to the bottom of the throttle body. There is a gasket between the plate and the throttle body, and that could be leaking, or the screws that hold the plate to the body could be loose. It is replaceable.
Not sure how this would relate to hard/delayed shifting.... It is possible you are getting coolant in the intake, since the plate also houses the idle air motor and part of the passages.
Fix the leaking coolant first, then see what happens with the shifting.
Old Mar 7, 2004 | 09:50 PM
OBE1 95Z28's Avatar
I'd suggest you do a TB bypass. Connect the hose from the radiator directly to the hard line that runs along the passenger side of the intake. This will cure your leak and keep your intake a bit cooler. The purpose of the coolant is to keep the intake from freezing up in extreme climates.
I'd suggest you look for vacuum leaks to see if that's what is causing your shifting issues.
Old Mar 7, 2004 | 10:56 PM
ScottZLT1's Avatar
There was a broken bolt on the bottom side of the throttler body, causeing the leak, but what would cause the car to shft hard, do you think the leak had something to do with it?
Old Mar 7, 2004 | 10:58 PM
ScottZLT1's Avatar
I re-installed the old one for now
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
