tHROTL BODY ????
Old Aug 30, 2004 | 07:06 PM
78sixbanger's Avatar
tHROTL BODY ????
OK, i think my hose on the bottom pass ide of the tb came off an thats what was spilling the coolant. Only thing is i cant find the hose, any help?
Old Aug 30, 2004 | 07:14 PM
gabeg94z's Avatar
Re: tHROTL BODY ????
only thing i can say is follow all the lines from radiato to tb and it shouldcome up .
Old Aug 30, 2004 | 07:34 PM
Bryan Smith's Avatar
If it was on the passanger side of the TB, then thats the one that runs into your heater hose. Just follow from the metal T (with bleeder screw) the smallest hose in the middle of that T is the hose that runs into the passanger side of the TB. The drivers side coolant hose runs from the TB then merges with the LARGE upper coolant hose on the drivers side of the radiator.
Good luck... Also while you're hunting around and fixing this. Just get a 3/8th's barb connector and splice the two hoses from the tb together. AKA the TB bypass.
Old Aug 30, 2004 | 07:40 PM
thanks guys, but i was hoping for the best. Just let the car warm up ad got under it when i turned it off. Time for a new water pump. Came out of the weep hole
Old Aug 31, 2004 | 06:17 AM
Mtrhds94Z's Avatar
You describe 93-4 routing [from the metal T (with bleeder screw) the smallest hose in the middle of that T is the hose that runs into the passanger side of the TB. ]See shoebox' diagram: See #9 on http://shbox.com/1/heater_hoses_93-94.jpg
95-7 the TB hose comes from the rear coolant crossover pipe to the psgr side of TB.... see #9 on
http://shbox.com/1/heater_hoses.jpg
You also describe 93-4 TB bypass.. 95-7 is different.. to do it:
http://shbox.com/1/95-97_hoses.jpg
Remove hose #4, then take hose #5 and run it from the radiator [it's already hooked up there]to the rear coolant crossover pipe #6
HectorM52
Jul 30, 2017 11:46 AM
mark0006
Apr 21, 2015 12:42 PM
CARiD
Feb 9, 2015 09:35 AM
CARiD
Jan 14, 2015 04:00 AM
CARiD
Dec 26, 2014 04:20 AM
