threw a rod tonight....
Old Nov 15, 2004 | 11:33 AM
  #16
WS Sick's Avatar
Re: threw a rod tonight....
You cannot put the pistons in from below, unless you machine the humps out of the block, would be a trick.
Old Nov 15, 2004 | 01:06 PM
  #17
1stz28's Avatar
That's kinda what I was thinking...just wanted to make sure I didn't miss something.
Old Nov 15, 2004 | 04:29 PM
  #18
Mystic97Z's Avatar
well talked things over with the dad tonight, we are going to be pulling the engine,,
for a 396 kit i need to have my block bored correct?
for a 383 stroker kit i just need to get a kit?
i would like to go 396 but don't want to have my block bored.
well, after this little project, the car is going from an everyday driver to a weekend warrior, so it will be getting a much larger cam.
what kind of hp can i expect with a 383 stroker bottom end?
what kind of hp gain will i see from a 383 to a 396?
the car should be arould 370-390 rwhp as is,
fully built top end w/ a stock bottom end.
thanks again for the help, as some of u may know, these are tough times...
Old Nov 15, 2004 | 04:39 PM
  #19
WS Sick's Avatar
For the traditional 383 you'll need the block bored .030. but they make a new crank with a 3.8 stroke that will make a 383 with the stock 4.00 inch bore, GMPP has the pistons and the crank. (I beleive the crank is made by Cola)
With close to 11:1 compression and some good flowing heads and a proper cam you can expect 420 plus RWHP and alot more torque.
Old Nov 15, 2004 | 04:45 PM
  #20
lillbush5555's Avatar
I have a complete 383 SB FS. it has 1200 miles on it with forged pistions and all arp bolts. here is a link.
http://web.camaross.com/forums/showthread.php?t=316721
Matt
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
MDZ28
Sep 7, 2015 09:16 PM
