thoughts on a cc306 with this valvetrain setup
Old Apr 16, 2008 | 07:29 PM
69z-28's Avatar
in a 100k mile LT1, mods as follows: CAI, long tubes and full exhaust, stock everything else, a simple cam swap, including these parts, yours thoughts.....
306 cam
Crane 10308 valve spring kit
Hardened 7.2 pushrods
3/8 Self Aligning 1.6 Roller Rockers
stock lifters
stock(replaced) timing chain
should be good to go?
Old Apr 16, 2008 | 07:37 PM
96' Formula WS6's Avatar
That sounds fine but you might want to look into a stall and gears to get good drivability at the lower RPM's
Old Apr 16, 2008 | 09:00 PM
69z-28's Avatar
6 speed and 3.42s, hoping to do 4.10s eventually. and a dynotune would be in the picture of coarse. just wanting the parts to be decent for each other. im aware that 7/16 studs, guideplates and whatnot would be the best thing but i'd like to keep it simple. motor wont be abused but it will be used for what its meant prolly see around 6500
Old Apr 16, 2008 | 09:05 PM
Bersaglieri's Avatar
That setup looks fine for 6500 and under. I'd spend some extra buck on one peice pushrods if it were me...only like $60.
-Dustin-
Old Apr 16, 2008 | 10:21 PM
Z28LT1_Just_Nasty's Avatar
It would be smart to replace the timing gears with the chain. Although people do just replace only the chain, this "can" be done but shouldn't. You should always replace a timing chain and sprockets as a set, they wear together. You may not be able to see the wear by just looking at it but its there. You are far more likely to have a timing chain failure without replacing the sprockets as well.
Old Apr 16, 2008 | 10:25 PM
mdacton's Avatar
Ive never seen it. I see the chains strech but no wear..... never seen 1st hand a failure of a stock style either.
Whats the spring info? I'm not looking it up....
Pushrods are worth the mony....so get good ones. You can get good ones for under $100
Old Apr 16, 2008 | 10:35 PM
Springs are a LTX aluminum head kit. It's what LE uses on his ligher duty cams. They could support a GM847 with no problems. They are basically the 99893 springs.
-Dustin-
Old Apr 16, 2008 | 10:41 PM
Doh sorry forgot to look at the sig, and to think people get yelled at all the time for not having one and i dont even read yours. Good luck with the mods man.
Old Apr 16, 2008 | 10:45 PM
69z-28's Avatar
hehe no prob 96' form.
i've always heard about loose timing chains on LT1s, my old WS6, i noticed alot of slack in the stocker and simply swapping the chain took out enough slack to satisfy me.
the springs will hold up im sure, they have ****ty "shims" but i didnt have problems with them on my old car.
as far as pushrods, will some basic hardened ones do alright (thunder racing has comp "hi-energery hardened PR's 7.2 length" for under 40 bucks.
and stock lifters (assuming good shape upon teardown) will suffice with a 306 ya....?
thanks guys
Old Apr 16, 2008 | 10:53 PM
mdacton's Avatar
http://store.summitracing.com/egnsea...115+4294779183
those work good. and cheap
don't buy those elcheapo welded ones.
The lifter should be fine....I have never used anything besides a stock lifter
Old Apr 16, 2008 | 10:54 PM
Sinister95Z's Avatar
They will work alright, but some people like myself upgrade to the one piece pushrods just for piece of mind. The hardened ones for about $40 are usually welded tips and are made of three different pieces.
If you want a good price on some very low mileage 7.2 hardened pushrods and comp guide plates, shoot me a PM. I just switched mine out last minute before we put the motor back in my car. PM me here or over on PC.
Old Apr 17, 2008 | 12:10 AM
SS RRR's Avatar
If it were me I would go wtih NSA rockers for anything past 6000rpm. That's just me though. As said, good pushrods are a must.
Old Apr 17, 2008 | 12:17 AM
69z-28's Avatar
my old setup was as follows, it saw 6300 RPM and 125 wet shot of nitrous....
224/224 cam
10308 crane spring kit
comp hardened 7.2 pushrods
LT4 1.6 3/8 self aligning Roller Rockers
stock lifters
stock timing chain
like i said, never had problems with the setup and it was doing around 425 horse on the juice, rev limiter set to 6500, shifting around 6300
Old Apr 17, 2008 | 08:36 AM
truedualws6's Avatar
Originally Posted by mdacton
TFS with a discount. It's probably the same pushrod I just paid $10 more for to get the name. And the TFS pushrods are a lot less than the equivalent Comps.
Other than I don't like the cheezy shims in the 10308 kit, I do like those Crane springs. I'd like to see someone post their installed height with this kit to see if there is a way to use a decent spring locator and achieve a 1.80" installed height.
DirtyDaveW
Dec 1, 2016 05:37 PM
mightymouse383
Jul 20, 2016 07:34 AM
maybe2fast
Mar 13, 2015 11:48 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
