Thoughts on cam and help with motor... Solid roller 244/244 .611/.611 112lsa
I need some help here...
I have this cam, its a cam motions R2441-12 sollid roller. specs are dur at 50 244/244 and lift with 1.6 RR is .611/.611 lobe seperation is 112...
So its a single patter obviously.. i have move detailed specs if you need them to help me.
What i am asking for help on is: is anyone running this cam or simular? based on your knowlage, what do you think of it and its charictaristics
I am having some heads done and the porter is asking me all these questiona and i dont know what to say...
with this cam and a stock shortblock, want kind of compression ratio should i aim for? i thought 11.8:1 but he freaked out with i said that. but maybe he doesn't know about reverse cooling. what CC should the chambers be to run this?
I am looking to have 430 RWHP daily driver, lots of vacume....do you think its obtainable? Should i sell the cam and go hydro?
Here are some detailsif you wanna know
97 LT1
hooker LT, 58mm TB, Computer tuning, heads with be full port stock casting with 2.02 and 1.6 valves
THANKS ALOT
97 LT1
THANKS ALOT
Re: Thoughts on cam and help with motor... Solid roller 244/244 .611/.611 112lsa
97 LT1
THANKS ALOT
97 LT1
THANKS ALOT
Rich Krause
Originally posted by Dr.Mudge
Vulva ran a solid like that on a 114 on stock heads, 93, "bad tune" and made ~400 RW.
Hunt him down or look for JimS on how to contact him.
Your running, advanced inductions heads right? do you think phil with flex a little bit with me to make a head that is solid roller compatable?(springs and valve seats)
JimS ran a 230/230 -110 on his 383 FWIW, and made fine power. I think his reason for a single pattern was midrange power, I haven't seen his dyno sheet in awhile, probably on his site:
http://v8beast.homestead.com/
I believe he turned 430 RWHP?
Are you going to spray this motor? I think I would invest in some forged bottom end parts. That motor should sound really good and pull pretty strong as long as everyhting else is matched. Good luck with everything.
No, not gunna be spraying it as of now, but i am buying a low mile stock shortblock from a freind...this way i will have two complete motors(the near stock one now and ther built one)
i figure it will be ok till 6500 rpm...if anything ever broke tho, i could just put the other one in and the build it.
i guess i should tell who ever is doing my heads the really make sure the exhuast flows well. Nobody here think that i sure go with a bigger valve on the E side?
full ported stock heads with 2.02 and 1.6 valves...hoping to get 210-215 cfm at .600 lift exhaust
correct me if im wrong.
Originally posted by 97Z-M6
i dont know of anybody getting 210 -215 on a set of stock cast heads. loyds getting 188 192 but 215 is a stretch i think.
95chwagon
Jan 13, 2015 09:19 PM
