Those who have upgraded to LS1 Alum. Driveshaft...
Old Sep 22, 2003 | 11:36 AM
pillagenburn's Avatar
Did you all upgrade/replace the transmission slipyoke? I was using the stock Trans. Slipyoke that came with my LS1 alum. driveshaft and the metal balancer on it cracked (i'm guessing from my SPEC Stage 3 6-puck ceramic clutch?). This caused a NASTY drivetrain vibration. I then ordered a stock LT1 steel driveshaft to take the balancer off of it ($20 shipped from speedautomotive.com) and noticed that the slipyoke shaft on the steel DS is actually somewhat longer than the trans. slipyoke shaft on the LS1 - I'm guessing this provides added strength. If anyone else has an experience with this, let me know!
thanks!
Old Sep 22, 2003 | 11:47 AM
SWINGRRR's Avatar
I just pulled the old one out and put the new one in. Took me about 30 minutes. Havent had a problem yet, but I have a 93 A4. Hope you get it figured out.
Old Sep 22, 2003 | 11:49 AM
everything is all figured out - i went ahead with the trans. slipyoke replacement. Us T56 people with clutch upgrades might need the stronger slipyoke though only because of the strain put on the drivetrain.
mrwz28
Jul 8, 2015 09:11 PM
camaro02DK
Jul 5, 2015 09:04 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
