Those with Nitto DR's that drive Street please
Old Jun 17, 2003 | 04:59 PM
  #16
97silverz28's Avatar
From my experience, I have to say that I agree with buttercup 100%.
Also, just to clarify, F1 cars do not race on full slicks.
The new road & track has an interesting article on tires & tire tech in F1 racing.
Old Jun 17, 2003 | 09:47 PM
  #17
94 CAMRO Z28's Avatar
I have the same size tire 245/50/16s and I did notice a difference in cornering a little bit. Compared to my Z rated Cooper Cobras before, these tires for sure have a softer sidewall. Steering is still pretty responsive though and off the line they are great on the street. Now I just need to figure out how to launch on these suckers. I always bogg down or spin at the track...<--6 spd.
Aaron
Old Jun 17, 2003 | 10:03 PM
  #18
magius231's Avatar
Originally posted by PatriotTA
Your cornering ability will improve with DRs (unless its raining of course). DRs improve traction all the time, whether its straight line or into corners. The basic idea is that there is more rubber contacting the road, and there will always be more rubber, whether you are auto-xing or drag racing. Many people use DRs for auto-x. That's why Nascars and F1 cars and any other race cars use full slick tires - more contact patch. And just a bit of knowledge, DRs are no worse than regular street tires when its just damp out with a little water on the ground. Treaded tires only help when there is water to channel away from your tire. If the ground is just wet (but no water on the surface) then you need to be careful, but don't crap your pants if you have to drive home or anything.
Actually, a great drag radial still won't hold a candle to an even somewhat decent road race tire. Also, the idea really isn't more rubber on the road, it has to do with rubber compound...simply put a smaller size drag radial will stick better than a big size regular radial due to the soft compound in the tires. The full slick tires that NASCAR uses are NOT drag slicks, they are specifically designed with great sidewall strength to handle the turns...the same tires would not be as good in a drag racing situation (not enough "wrinkle"). Wet conditions are bad period for drag radials...you would be shocked how much the grooves/sipes/etc in a tire help out with wet conditions, standing water or not...
Seriously, find some good regular radials for the street and save the DR's for the track...too expensive to wear down and too risky if you get caught in a sudden downpour...
Old Jun 17, 2003 | 11:04 PM
  #19
94formulabz's Avatar
Too risky? it's called slow down or pull over if you have to. I frankly don't give a crap if traffic backs up behind me when it's raining. i would still play it safe even if i had the best rain tire out there in a high horsepower rear wheel drive car. I have a lowered fbody with bald BFG comps on the front and nitto dr on the back. The traffic doesn't ever really back up behind me, i just don't tailgate (wet or dry). Drive like they teach you in drivers ed, I don't think it's an issue as long as you drive sensibly and understand that water is a lubricant on the road surface. Nitto drags RULE!
Old Jun 17, 2003 | 11:14 PM
  #20
LT1ponykilla's Avatar
Originally posted by Gripenfelter
I've used my Nitto DRs on the street for about 3 yrs now and I love them.
I have about 10K miles on them and they corner BETTER than my GSCs.
In fact, I need stickier tires for the front now because the rears stick so well they push my nose out on turns.
In that video did you have the Nittos on there? I think you had a pretty good launch there. Do you have the stock 7.5'' rear?
Old Jun 17, 2003 | 11:17 PM
  #21
m0nk's Avatar
I drove with BALD nitto 315/35/17s in the pouring rain. Now that I think about it, it wasnt very smart of me, but I wasnt really thinking about it. I was going 65 on a highway n hit a lil puddle and shifted over about 2 feet, coulda been bad. So after that I went no faster than 55. And was totally fine, maybe the slightest movement, but barly noticible, and this was on bald nitto's. Look on my website, 3rd picture down I believe, you will see the no tread. Now I have brand new ones, but still will not be going over 55 in rain. But there is no reason why I wouldnt feel safe driving with treaded nittos in the rain.
Old Jun 18, 2003 | 07:09 AM
  #22
JAFO1994's Avatar
Aaron
You must be running at KK there. I was an Oshkosh Native until a year ago and used to run my bike up there. Moved to Florida here and hate it, will be moving back to Oshkosh August 18. The only good thing down here was I bought a super clean Z that I will be bringing back home. I'll need to take her KK to see what she runs. Hopefully, a cam this winter first though.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Ringmaster72
Feb 25, 2015 03:15 PM
Jason Short
Jan 19, 2015 06:33 PM
