Those with LE heads/cam come inside
Old Oct 22, 2004 | 02:37 AM
  #16
1982z28with18s's Avatar
Re: Those with LE heads/cam come inside
TTT....
I sold my old motor to my buddy and now have a 383 with LE2 package. Should have dyno/track numbers in a few weeks.
Old Oct 22, 2004 | 06:04 AM
  #17
TQdrivenws6's Avatar
Well for those of you who missed it, My car put down 408.8/395.7 SAE with an ignition issue. My Delteq gets here today, and I might just have to head back to the dyno this week
Chris
Old Oct 22, 2004 | 01:22 PM
  #18
SStrokerAce's Avatar
Chris
Did you check the valves to make sure that they were straight?
"we can see where there was contact with the valves and pistons on the LE1 cam. "
Bret
Old Oct 22, 2004 | 01:43 PM
  #19
Bret
Yes sir. The contact was only enough to scuff the carbon on the top of the piston, I think we got pretty lucky in that regard. We lapped each valve, and filled the port with water, and both showed a very positive seal.
Chris
Old Oct 25, 2004 | 02:45 PM
  #20
Fastbird93's Avatar
Chris
Just saw this!! Nice numbers. Get that ignition issue fixed and head back for an update!
Old Oct 25, 2004 | 03:02 PM
  #21
Hybrid86Z's Avatar
nice numbers gentlemen!
i can't wait till my LE heads / cam can be purchased!
Old Nov 16, 2004 | 04:49 AM
  #22
TTT...I ended up breaking the timing chain my 383 with less than 500 miles, but it should be back in the car this weekend. Hoping to have dyno #'s by the end of next week and track #'s the following Sunday. Might even get a few nitrous passes in if the dr's are holding up good enough.
Shooting for 11's n/a on dr's first time out to the track with the 383.
Old Nov 16, 2004 | 07:07 AM
  #23
bunker's Avatar
Going back to the dyno soon, was running 11.9 A/F and blew a header gasket before I got a chance to tune her, best was 405RWHP/360RWTQ SAE corrected, still a 350. Hoping for 415+ next time
OOPS I said head gasket, I meant header LOL.
Old Nov 16, 2004 | 09:16 AM
  #24
OldSchoolSS's Avatar
What kind of gas mileage are you guys with the le2 cam and heads getting? My car is a daily driver so I don't want to hurt it to much. Right now it's an automatic but I do want to convert it over to a 6 speed.
Old Nov 16, 2004 | 10:38 AM
  #25
30thannZ28's Avatar
I don't have times yet, but mods in sig. FWIW, I bought the comp 233/239 XE 112 lsa cam about one month before lloyd started doing custom grinds and I wish I would've waited for one of his cams....
My car pulls like an SOB tho...
Old Nov 16, 2004 | 05:00 PM
  #26
Kory 88 Iroc Lt-1's Avatar
My last time at the track, I was having traction problems best 60' was 2.14. I ran a 13.00 at 114mph. I am thinking of replacing my hot cam with one of Lloyds cams. Think I cound get 4 or 5mph out of an LE2???
Kory
Old Nov 16, 2004 | 05:09 PM
  #27
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
375/360 w/ DIY home ported heads and LE2 cam... 357cu. in.. stock crank and rods, heavy speedpro forged pistons.
I can only get it to pull to 6k right now.. I can rev to 7k.. But power drops off really fast - and the A/F dips way rich. Once I get that issue solved, I'll prolly pick up on peak power too. We'll see. I'm not too worried about it
Old Nov 24, 2004 | 04:33 AM
  #28
TTT...No dyno #'s yet with the 383, but I did get two shakedown passes. Best of the two was 11.78 at 115.6 with a 1.64 60ft on DRAG RADIALS. I got my goal. Hopefully I'll have dyno #'s this weekend and will get a few more passes in with a better tune and the shift points set back up.
I created a post about my passes here...
http://web.camaross.com/forums/showt...&highlight=383
Old Nov 24, 2004 | 02:01 PM
  #29
RealQuick's Avatar
LE Ported heads (before he started the LE1, LE2, etc.). They had the 2.00/1.56 valves and flowed 271/187 @ .550" and I had a XE230/236 .544/.556 114LSA cam. With a mailorder tune I made 383rwhp/353rwtq. I only got to the track with an older tune (368rwhp336rwtq) and still ran 2.07 60' 8.2/90mph and 12.5/114mph.
Old Nov 24, 2004 | 02:36 PM
  #30
bunker's Avatar
BTW up top I posted "head gasket" I meant I blew a header gasket, my Air Fuel ratio was 11.9 but still got 405rwhp/360rwtq out of a stock 350 with LE heads and LE 3 cam, I'm hoping for 410-415rwhp next time through 12 bolt.
