Those with duals under the axle
Old Oct 5, 2004 | 07:01 PM
lt4 fd's Avatar
I remember I think it was got hp? that had the red T/A with duals under the axle and wanted to ask how much clearance there was between the rear sway bar and the exhaust. Anyone else who has done it that could help please reply as well I would like all the help I can get I was also thinking of doing 3" all the way back but could just as easily put a 3" to 2.5" reducer after the muffler and run 2.5" under the axle. I dont see why more people dont do this, unless your offroading or have large rocks in the middle of the road you wouldnt run into any problems... especially because of the price though.
Old Oct 5, 2004 | 07:06 PM
funina91ss's Avatar
Re: Those with duals under the axle
what happens when you jack your car up? The rear end drops down I can just see this being a problem when hitting a hump in the road and your car does one of those rollacoaster deals. But that is just me thinking
Old Oct 5, 2004 | 09:12 PM
got_hp?'s Avatar
i installed two flanges before the axle, so when i want to put the car on a lift, or goto the track, i can unbolt the back part of my exhaust and it dumps before the axle.
as far as humps in the road, i have never hit the pipes at all and i got over all kinds of humps and speed bumps, the roads here blow.
i used 2.5" all the way back from the headers.
Old Oct 5, 2004 | 09:16 PM
Firehawk_Dude's Avatar
BMR sells a Panhard rod reloaction kit that makes it possible to use 3" over the axle for duels.
You can find it here
Old Oct 5, 2004 | 10:36 PM
viperkiller's Avatar
not what you asked, but i run 2.75 over the axlewith stock panhard bar. never had a problem exept for just behind the collector but thats with anything. the only thought i would have has already been adressed. he said he removes the back half of his exhaust, i could just see the pipes being crushed the first time it hooks.
Old Oct 6, 2004 | 04:52 PM
lt4 fd's Avatar
I was thinking about reducing the exhaust size just after the mufflers and just before the rear end to 2.5" from 3" and curious if it will hurt or help performance or do much anything. I figure since the exhaust is cooler and reduced in volume a smaller pipe would keep velocity higher and help clearance but it might just be a crappy idea, what do you guys think?
Old Oct 6, 2004 | 05:08 PM
RedLT4Mike's Avatar
I have em under the axle...
I've had no problems with them at all.
Been up on a body lift...been jacked up...no prob's
see my other comments, and PICTURES on this thread
from fbody.com...(I'm viperkiller)
http://www.fbody.com/cgi-bin/lt1/read.cgi?msgid=214914
Old Oct 6, 2004 | 05:10 PM
RedLT4Mike's Avatar
crap! there is another viperkiller on this thread! well....thats my name on fbody....Hello viperkiller
Old Oct 6, 2004 | 09:36 PM
lt4 fd's Avatar
thats pretty cool, about how much clearance is there between the lowest hanging part of the car, swaybar I think, and the exhaust system at rest?
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
