Thinking of adding A STS rear TURBO
Old Dec 14, 2004 | 12:53 AM
Dmx4ever3's Avatar
Question Thinking of adding A STS rear TURBO
ok i have a 95 lt1 with 224/230 cam and 410 gears and bored .30 to 355 was thinking of getting this turbo system.... check it out at www.jlturbo.com or www.ststurbo.com at jlturbo there are sound clips and movie clips ... really cool to watch now should i go turbo and will my engine hold up and at what boost lvl and ..... what orther changes do i need to make ... like injekters ?? 36 pound ??? intake throttle body??? help me out guys , or go supercharger?
read up about this differences at ststurbo between the 2 systems plz leave ur feedback on this
Old Dec 14, 2004 | 01:00 AM
SS MPSTR's Avatar
Re: Thinking of adding A STS rear TURBO
There is so much information and discussion in the archives here - did you try the search feature?
Old Dec 14, 2004 | 01:04 AM
Dmx4ever3's Avatar
yea i did try ... i looked for sts turbo i got nothing on it rear monuted turbo
Old Dec 14, 2004 | 02:04 AM
Dmx4ever3's Avatar
ok i must of typed it in wrong i now went over other posts but still this didn't answer my ? with my setup and my cam how will this work on my engine ..... is it a bad idea since i don't have a cam made 4 a turbo ..... i need some feedback from people that know about this ststurbo kit and has worked around them and cams like mine
Old Dec 14, 2004 | 06:54 AM
godofdragons's Avatar
my opinion for forced induction on these engines is go big or go home. i would only put turbos on after i built up the bottom end. ive just never felt it was worth all the time and effort if you arent going to run forged components and low compression, look into nitrous maybe, but hey its your engine
EDIT: i just noticed that you seem to enjoy the looks aspect in modding more than alot of us so it dawned on me maybe you want the novelty of a turbo as well as the performance. in that case, i think the rear turbo is probably one of the best choices. real simple installation and you get that sound, the bragging rights of a turbo v8, and the power.
Old Dec 14, 2004 | 07:28 AM
RealQuick's Avatar
You can run stock tb, but you need 42# injectors and a good tune.
Old Dec 14, 2004 | 07:48 AM
Shon Herron's Avatar
Just have to watch the compression ratio.
Old Dec 14, 2004 | 09:07 AM
96TurboTA's Avatar
Tbyrne.com has a cheaper starting price, and is also having a sale. Tbyrne is also a supporting sponsor.
Old Dec 14, 2004 | 10:01 AM
hotazzz28's Avatar
I was on STS's web site, the turbo sounds crappy. Anyone know if these are better than a regular mounted turbo.
Old Dec 14, 2004 | 10:07 AM
DavesLT1's Avatar
Wouldn't a twin 52mm TB help him to flow better? They're about $150 on Ebay for a bored and remanned one, and mine works even better than my stock, though I think my throttle shaft was a slight bit worn. Seems like it would help maximize the turbo as our intakes are set up to take a 52mm with no porting or different gasket.
Old Dec 14, 2004 | 10:29 AM
RealQuick's Avatar
They sound nice in person. A regular mounted turbo will have more potential in the end than an STS, but it can make 700rwhp reliably with the the upgrade top the t70 @ 15psi and a motor that will handle the boost.
Old Dec 14, 2004 | 10:31 AM
RealQuick's Avatar
A bigger one will help some, I just meant it wasnt a must have. Injecotrs and tuning are the must haves!
Chek the following link out. They put an STS on a big cubed LS1 and made 755rwhp/815rwtq.
http://www.ls1tech.com/forums/showth...2&page=1&pp=20
Old Dec 14, 2004 | 11:26 PM
Dmx4ever3's Avatar
so you guys r saying that it will work ok with my camed engine and i need like what size injecters and a good tune from where?
Old Dec 15, 2004 | 12:02 AM
dmoor88's Avatar
for the price, why not go with an intercooled ATI?
Old Dec 15, 2004 | 12:11 AM
5.0THIS's Avatar
You need to search in the forced induction section, not the LT1 tech section. I guarantee your question has been answered in that forum on more than one occasion. If you cant find the info in there then you're doing something wrong
