Think ill hit 11's????
Old Mar 22, 2005 | 06:20 PM
Propower1124's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
im am building up my motor when im done this is what it will be. Do you think i can hit 11's with this setup
Stock block, heads:
Engine:
K&N Cold Air intake
Comp Cam 306
Comp Hardened pushrods
Proform 1.5 roller rockers
isky double coil valve springs
LT4 Timing Chain
March Pulleys
CSI 37gpm electric water pump
Exhaust:
Edelbrock shorties
Y-Pipe
Flowtech cutout
or going to a borla system
Ignition
MSD 8.5MM wires
MSD blaster coil
Bosche platinum +2 plugs
BRAND NEW OPTI
Transmission:
Stock 4L60e
B&M Trans cooler
VIg 3 disc 3200 stall
Rear:
3.73 gears
PCM:
madz28 tune
Tires:
Kumbo ecsta ASX 275/40/18 95% thread
Suspension:
BMR Lower Control Arms
BMR Shock tower brace
Weight:
Stock seats replaced with lighter racing seats
Rear Seats removed
Old Mar 22, 2005 | 06:25 PM
jchevy's Avatar
Re: Think ill hit 11's????
Im gunna say mid 12s. Low 12s if you launch like a ****.
Old Mar 22, 2005 | 06:26 PM
What else would i need to hit 11's from this setup?
Old Mar 22, 2005 | 06:27 PM
ajschult's Avatar
N2O
Old Mar 22, 2005 | 06:29 PM
how long would my motor last if i spray it 2 or 3 times
Old Mar 22, 2005 | 06:33 PM
Heatmaker's Avatar
Advanced Member
um... no.... Not unless you connect a hose from your intake up your a** and fart in it to create a boost from the methane.
Old Mar 22, 2005 | 06:35 PM
I Got it, ill just go to wal-mart and get some stickers like NOS, Racing, etc. ill def hit 11's then
Old Mar 22, 2005 | 06:38 PM
Heatmaker's Avatar
Advanced Member
You got it... don't forget the Type-R badges... those are mandatory for 20hp each.
I say mid 12's
Jameslt1TA's Avatar
Have your heads ported. Or do lots of weight reduction. But if i remember right Atljar has run and 11.98 with stock heads and a gm847 cam.
But if i was you i would save up and put on some good heads...it will cost about as much as a complete n20 setup would, maybe a hair more.
Old Mar 22, 2005 | 07:10 PM
jchevy's Avatar
I would say get a good set of heads, and some et streets. You are also probably going to need better than a mail order tune. Its hard to get a good tune that way, it really needs to be put on a dyno and tuned. Some 1.6 rr's would help too.
The key to a quick ET is in the launch!!!!
Old Mar 22, 2005 | 07:18 PM
also forgot to mention
accell 30# injectors
Walbro 255lph fuel pump
Old Mar 22, 2005 | 07:27 PM
SAR2K's Avatar
Lightbulb Re: Think ill hit 11's????
Hooker long tubes (leaving a lot on the table with shortys) and some 4.10 gears for that M6, and good shifting and it should be in the bag... provided it's not 100 degrees on race day, LOL.
Steve...
Old Mar 22, 2005 | 08:54 PM
robb4964's Avatar
12.6-12.9
Old Mar 22, 2005 | 09:03 PM
mattybz28's Avatar
You're not gonna go anywhere without some tires...
Old Mar 23, 2005 | 09:42 AM
bski224's Avatar
You said it!!! NOt going anywhere w/out any slicks. Gotta get those heads done while your into your motor. I run 12.20's with a little hot cam and my clutch was original clutch slipping like a ****. Now i have SPECIII and cant wait till i get to track this season, hopefully hit 11.90 something. NOw is the time to do your heads if you got the top half apart. Also match your intake. I will put money that you should hit somewhere in the 11's. GOOD LUCK
