Think I have an 02 issue
Old May 3, 2014 | 03:22 PM
Macs95LT1's Avatar
Keep getting random SES light. Plug in my laptop and run a data master scan. Scan reveals failed right 02, DTC 63. Change 02 with new AC Delco 02 and clear DTC code. Start car and start scan again. Car reaches operating temp and new 02 cycles between 98-107, left 02 sits on 453. Shoudn't the left and right values be close to the same number?
Old May 3, 2014 | 04:13 PM
Re: Think I have an 02 issue
At hot idle, the numbers should fluctuate all over the place (a lot more than 98-107). Plus, the left O2 seems to be stuck or not working at all. Code 63 is an open circuit. Check your wiring.
Old May 3, 2014 | 05:50 PM
Macs95LT1's Avatar
Thank you. Everything looks okay with the wires, but I'll try replacing the 02 extension and go from there. Darn thing isn't that old.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
