Things to wathc out for at Engine rebuild shop, questions to ask?
Im taking my block to a machine shop tomorrow.
This shop is highly recommended by one of my friends who does head porting and car work on the side. And i would trust him doing work on my car.
But i just want to make sure everything sits right when I go talk to the guys are the machine shop..
For instance- If i go 383 pistons, should i have the pistons ordered 1st and then have them bore out the cylinder walls. Because i know each piston manufacture has a slight different size etc. This way they can match the bore exactly to the piston.
anything else i should know or ask the machine shop?
If they are really good they will know what to do without your having to prompt them.They should know a lot more about it than you (or I) do. To machine the block correctly they need the whole rotating assembly. If they don't know that, go somewhere else!
Rich Krause
Rich Krause
mspennyhughes
Nov 28, 2014 03:22 PM
Hal Fisher
Sep 14, 2002 09:36 PM
squirrels
Jul 13, 2002 01:58 AM
