Thin ground wire on pass. side of block by dipstick... what is it for?
Old Dec 26, 2003 | 02:35 PM
trax's Avatar
Question Thin ground wire on pass. side of block by dipstick... what is it for?
While debunking my airbag problem I noticed that I have a loose ground on the block. I haven't reconnected it yet but I'm wondering if it's tied in at all to the airbag system. Any ideas?
Old Dec 26, 2003 | 02:56 PM
carlos64030's Avatar
starter ground?
Old Dec 26, 2003 | 03:04 PM
Red96Lt1's Avatar
Originally posted by carlos64030
starter ground?
That's what I was thinking. The ground for the signal the starter gets from the switch, not the actual starter.
Old Dec 26, 2003 | 07:53 PM
Janny's Avatar
You sure that it isn't your knock sensor. It is thin, and it connects right near the dipstick area.
Old Dec 26, 2003 | 07:57 PM
InjectedSS's Avatar
knock sensors don't have a gound that goes to the block. knock sensor is only a single wire that goes to the ecm
Old Dec 26, 2003 | 07:59 PM
Hotwire's Avatar
it's a reference ground for your pcm. i saw the same one when i was pulling the motor for my s-10, looked it up in the service manual. reconnect it and make sure it has a good connection.
Old Dec 27, 2003 | 07:46 AM
Janny's Avatar
Absolutely correct, however, to the uninitiated it might appear to be a ground wire of some sort. Didn't want to see him cut or hack it, assuming that it was an insignificant ground wire. I know I almost did the first time I saw it.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Injuneer
Dec 15, 2014 09:36 AM
NAVY99
Oct 3, 2002 03:47 PM
PaulN64
Aug 8, 2002 05:39 AM
kandied91z
Aug 6, 2002 01:18 AM
