These are the SPECS on my new motor, any comments appriciated
Old Aug 5, 2004 | 06:47 PM
joebeemish's Avatar
I had my engine rebuilt. New CAM, Stage 2 port on heads, 383 stroker, etc. The numbers on the CAM:
290@ .500, 230, 114 degree lobe center, .480 lift
On the heads, Intake valve 2.02"
250.6 CFM at .500
269.8 CFM at .650
Exhaust valve - 1.57"
203.0 CFM at .500
214.7 CFM at .650
How do these numbers sound? Any tips on what changes I should make to the PCM parameters?
Thanks.
Old Aug 5, 2004 | 09:07 PM
97Z-M6's Avatar
Re: These are the SPECS on my new motor, any comments appriciated
we need alot more info as to cam specs, compresison ratio dynamic compresion, are these stock ported heads, what size injectors.
but i can tell you will need to have a comp. tune. it may not run at all with out a pcm tune, and if it does, i wouldnt do it long.
Old Aug 5, 2004 | 10:24 PM
joebeemish's Avatar
What type of CAM specs do I need, do you have an example?
The compression ratio is 9.5 to 1.
What is dynamic compression?
The heads are my stock heads with a stage 2 porting job.
The injectors are stock now (24 lbs), but I have 42.5 lbs injectors ready to be put in when I have the new program.
The car runs rough and sometimes hot the way it is now. What damage to the new motor are you concerned about if I drive it easy the way it is?
I know I need a profession tune, but I want to understand what needs to be done.
Any detailed questions that I can pass onto my engine builder would be appriciated. The guy that was going to tune my car after the rebuild flaked out and I am researching how to find the right guy for the job.
Thanks.
NewsBot
Dec 28, 2014 06:20 PM
ChrisFrez
Dec 7, 2014 11:32 AM
1LEThumper
Jul 14, 2003 12:45 PM
IDOXLR8
Aug 6, 2002 12:30 PM
