Are these Pro Mag Rockers Fugged up? Pic
Old Aug 23, 2003 | 07:01 PM
JucinGTA's Avatar
Its kind of blurry but its the best I could do. I have about 9 of these that are like this. See how they are scarred on the sides where the arrows are? They seem to roll fine.
Pic
Here
Also what is the difference in the rocker itself between Self Align and Non Self Align? I noticed that the not self aligning dont have the "Flaps" on each side where it rides the valve tip and prevents it from moving from side to side.
My friend is saying these are non self aligning but these have the Flaps on each side, so I keep telling him they are Self aligning.
Old Aug 23, 2003 | 07:17 PM
Eddie95Z28's Avatar
Those are self aligning.. as far as the scarring I had ONE like that that I used anyway and everything seems fine so far... but if I had nine of them I would call Comp and find out what they would recommend.
Old Aug 24, 2003 | 07:45 AM
slopokrodrigez's Avatar
I'm pretty sure those are not self aligning and you will find out that they have to have guide plates.
I noticed one in the picture has the trunnion upside down. Were they all installed correctly with the trunnion right side up?
Did you measure the length of the pushrods to see if they are correct? try this if you need it:
http://www.compcams.com/information/Products/Pushrods/
Old Aug 24, 2003 | 08:01 AM
Don 97 SS's Avatar
While I am not certain, those do not appear to be self aligning rockers, which might explain the damaged apparent damage to the tips.
Old Aug 24, 2003 | 09:30 AM
KOSletten's Avatar
From what I can tell from your photo is that your rockers ARE self aligning. http://www.compcams.com/catalog/286.html
Some of my CCPMSA rockers are showing appreciable wear on the inside edges of the tip guides(flaps, ears or whaterver you call them) after only 500 miles. I think I will be calling CC and see what they have to say about the wear.
Old Aug 24, 2003 | 11:32 AM
Don 97 SS's Avatar
Those do appear to be the same as the ones in his photo. I'm surprised a maufacturer with the reputation of Comp has what seems to me to be a poor design. I'm glad I went with Crower self-aligning 1.6RRs.
Old Aug 24, 2003 | 12:02 PM
Anyone that thinks that design will work needs to buy the ocean front property I have in Ohio. What S@#$. They still need guide plates.
Old Aug 24, 2003 | 12:50 PM
JucinGTA's Avatar
Im gonna get on the horn with come because they say the body of the Rocker is Guaranteed for life.
Old Aug 24, 2003 | 01:06 PM
EviLZ28's Avatar
I thought you could not run self aligning rockers with guide plates? I thought it would bind in the valvetrain?
Old Aug 24, 2003 | 01:10 PM
turbo_Z's Avatar
those definitely are self aligning rockers. what it appears may have happened is someone installed guideplates anyway which put excessive wear on those flaps or guides. im not sure if theyd be alright to use anymore.. definitely not as self aligned anyway. maybe you could grind off those guides and then theyd work as nonself aligned?
Old Aug 24, 2003 | 02:13 PM
JucinGTA's Avatar
Yup guide plates were used from who I got them from.
Old Aug 24, 2003 | 04:25 PM
KOSletten's Avatar
Mine were not used with guideplates and still are showing what I think is excessive wear. It seems to be a poor design and in 20/20 hindsight I should have went with the NSA rockers.
Old Aug 25, 2003 | 01:30 PM
JucinGTA's Avatar
Update I just talked to the guys at Comp Cams and showed them the pic, they said they will cover that and it shouldnt do it. All I have to do is send in the bad ones and they will take care of it. Give them a call if yours did the same. Lifetime warranty.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
cmyname1
Feb 19, 2015 08:38 PM
