Are these decent springs?
Old Oct 28, 2006 | 04:29 PM
net_coma's Avatar
I have these springs on hand. Are they suitable for use with CC503 cam and 1.6 rockers? Know nothing about them and do not recall seeing them mentioned in posts. Part number is 8805-A.
Brand: Isky Racing Cams
Product Line: Isky Valve Springs
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.530 in.
Coil Bind Height (in): 1.160 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 400 lbs./in.
Inside Diameter of Outer Spring (in): 1.110 in.
Inside Diameter of Inner Spring (in): 0.730 in.
Valve Spring Style: Standard
Coated: No
Quantity: Sold as a set of 16.
Valve Springs, Dual, 1.530 in. Outside Diameter, 400 lbs./in. Rate, 1.160 in. Coil Bind Height, Set of 16
Old Oct 28, 2006 | 04:48 PM
SStrokerAce's Avatar
Isky makes good stuff, depends on what height you install them at.
Old Oct 28, 2006 | 08:37 PM
zx1216's Avatar
get some comp cams 918 beeheives, then when you want a biger cam you won't have to change the springs
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
ChrisFrez
Mar 29, 2015 09:43 PM
