Thermostat or water pump maybe?
Old Jul 31, 2006 | 04:53 AM
njenson's Avatar
Went out to meet up with the family yesterday (first day above 100 im sure the car has seen possibly ever). anyways I was driving around for about 45 min or so (mixed highway and city) no temp problems at all. i stopped at a gas station for about 4-5 min and left. Before i got out of the parking lot i spotted the guage start to spike, so i quick turned it off before it redlined (was close).
After that i opened the hood and let it cool for a couple seconds and watched coolant come out the resavoir. after a few minutes i checked the temp, started it so i could park it....watched it and the problem went away, WTF.
To finish i ended up just finishing the drive to the relatives (couple miles) and had no problems.. filled it with water, which was not even near a gallon and had no more problems the rest of the day....while using the A/C
Anyone know what the problem could be? I would think the stat first but it wouldnt have cooled down in 5 min to close, would it?
Old Jul 31, 2006 | 06:02 AM
SS RRR's Avatar
Re: Thermostat or water pump maybe?
A gallon is ALOT considering the cooling syst. holds around 14-16qts.
Where did the coolant go? You need to find out.
Check your fans and check to see if your t-stat is operational.
Old Jul 31, 2006 | 06:09 AM
njenson's Avatar
it really wasnt a whole lot. maybe 1 liter in the radiator... for good measure i put a good ammount in the resivoir
Old Jul 31, 2006 | 06:31 AM
SS RRR's Avatar
It'd still be a good idea to find out why you lost that much coolant.
Old Jul 31, 2006 | 12:00 PM
njenson's Avatar
thats why i fugured id ask u guys for good places to look first
Old Jul 31, 2006 | 12:14 PM
Javier97Z28's Avatar
Moderator
In most water pump failures the coolant seeps or in some cases POURS out of the weep hole at the bottom of the pump. Easy enough to check.
willismoons
May 27, 2015 04:03 PM
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
thenewkid
Apr 12, 2015 07:42 PM
pologreen97z
Dec 2, 2014 10:42 AM
