thermostat function??
Old Sep 25, 2007 | 02:51 PM
will62085's Avatar
On an LT1 long style thermostat, should the bottom spring open at the same temperature as the top spring? What exactly is the purpose of the bottom spring?
Old Sep 25, 2007 | 02:58 PM
As the thermostat opens, the bottom part elongates and seals a port in the pump. That allows the coolant to properly flow back and forth from the engine to the radiator for cooling. When the thermostat is closed the open port allows coolant to circulate more in the engine and pump.
marlar98
Sep 12, 2018 07:18 AM
Jeff1904
Jun 5, 2016 05:00 PM
CARiD
Sep 30, 2015 05:44 AM
4586
Aug 24, 2015 11:04 PM
Aug 5, 2015 08:35 AM
