thermastat in the water pump?
Old Jul 20, 2006 | 12:50 PM
95 N2OT/A's Avatar
i bought this car yesterday let my friend drive it and he blew out the water pump
when i was removing the water pump i noticed there was no thermastat in it
can this present a problem? should i leave it as is or put a new thermastat in it?
thanks
robbie
Old Jul 20, 2006 | 12:56 PM
user 647483's Avatar
Re: thermastat in the water pump?
The water inlet "neck" is held down by 2 bolts just below the throttle body.
Your thermostat should be inside that.
Pictures http://shbox.com/1/tstat.jpg
Don't run a car without one, the cooling system can't function properly without it. It's a $10 part and installs in a few seconds.
Be SURE to use the LT1 "tall" thermostat, the short SBC ones will not work.
HOWTO http://shbox.com/1/4th_gen_tech2.html#thermostat_change
Old Jul 20, 2006 | 01:18 PM
sbs's Avatar
sbs
Originally Posted by James Montigny
The thermostat is located on the intake manifold above the water pump.
Uh, no, it's in the water pump. As is shown by the pics you linked.
Yes.
I suggest looking now for whatever else the previous owner hacked up before something else blows up.
Old Jul 20, 2006 | 01:22 PM
Sweetred95ta's Avatar
I've head that running it that way:
1. Builds sludge (I don't know why)
2. Cools the front cylinders but lets the back cylinders get extremely hot.
Get one in it.
Old Jul 20, 2006 | 01:33 PM
RedRyder518's Avatar
The base hangs down against the waterpump, but it not inside it.
If you take the WP off, you won't find a thermostat in it.
You have to take the neck off. (Changing a T-stat does not
require removing the pump)
I think either your are confused or we are confused of your wording. The thermostat is located on top of the water pump housing.
Old Jul 20, 2006 | 01:37 PM
OMG, I'm an idiot.
Yes, it's sitting on top of the water pump housing.
I was spacing out and thinking of a different engine altogether.
Sorry guys, I'll shut up now.
Old Jul 20, 2006 | 05:00 PM
TAEnvy's Avatar
I didnt know you could "blow" a waterpump just driving it, how does this happen?
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
