Is there a way to test the opti when its not on the car?
Old Oct 31, 2005 | 03:24 PM
Jameslt1TA's Avatar
Soon i will have all the parts for my engine and be able to put it back together, but i dont want to put the opti back on if its gona go out soon.
Im pretty sure it worked fine but would like to know if i should just go ahead and buy one or not.
So is there a quick test or something to see if my old one is good?
James
Old Oct 31, 2005 | 04:38 PM
sssalah's Avatar
Re: Is there a way to test the opti when its not on the car?
By connecting the opti to its harness and rotating it by hand, the injectors should be ticking. Also when connected to the coil should give spark at coil/plugs.
Old Oct 31, 2005 | 04:51 PM
Jameslt1TA's Avatar
Cool, thanks i didnt want to havel to take the opti off once my engine is together and in the car.
Old Nov 1, 2005 | 05:36 AM
Tom Piper's Avatar
You can also bench-test it with a regulated 5 volt power supply while looking at the output of the low-res and high-res pulses with an oscilloscope -- also, rotating it by hand.
Tom Piper
MadMav
Feb 6, 2015 11:02 PM
Injuneer
Dec 15, 2014 09:36 AM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
naaz90
Jul 27, 2002 08:22 AM
