Is there a way to test the evaporator core itself?
Old May 21, 2005 | 09:51 AM
PatrickCarter's Avatar
I think I have a leaking evap core, is there a way to test it without having to pull the entire dash apart?
P
Old May 22, 2005 | 07:49 AM
slopokrodrigez's Avatar
Re: Is there a way to test the evaporator core itself?
You can kill 2 birds with one stone IF YOUR AC HAS LOST IT'S CHARGE. Evacuate the system just as you would when preparing to recharge it. If it won't hold vacuum, it's easy to find the problem at that point.
Old May 22, 2005 | 06:17 PM
Right, well i know there is a leak, if all the freon leaks out I'm sure there is a leak. This is on my 1999 cherokee, but same pricipal, its takes about a month for a full charge to depleat, I would like to be alittle more sure then i think its the core, its about a 9 hour job to do it for a $99 part, just alot of work to still have a problem. I was just looking for a way to check it before i assume thats what it is.
Patrick
KYWes
Jun 14, 2022 06:52 AM
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
cmsmith
Sep 14, 2015 09:25 PM
karpetcm
Aug 14, 2015 03:02 PM
ducttape1975
Jul 10, 2015 06:29 PM
