Is there a way to repair this? (pic)
Old Jan 19, 2008 | 01:49 AM
ssbowtie1's Avatar
I wonder if the dealership can still get parts like these.
Old Jan 19, 2008 | 01:56 AM
jammer94's Avatar
aw man just get some 1/4 hose and put 2 and 2 together bud thats an easy fix there...if not 1/4 find the size that is the tightest on the plastic tube and put 2 tiestraps on it if it makes you feel comfortable but its not as critical as you may have thought.
Old Jan 19, 2008 | 01:58 AM
mrmint69's Avatar
Its one of the most broken parts on the Camaros. They are $20 or so through the dealer and $10 on Ebay for an aftermarket one. They need to be spliced on either route and the AC Delco one looks just like the ones on Ebay so its your call.
Old Jan 19, 2008 | 02:00 AM
ssbowtie1's Avatar
Old Jan 19, 2008 | 02:02 AM
ssbowtie1's Avatar
Thanks jammer...I might just repair it with some hose if I can't find a replacement.
Do you know what its called?
Edit...actually I'm thinking you're referring to the broken plug...that's not what I'm worried about
Old Jan 19, 2008 | 07:27 AM
If it is the EVAP hose, you can still get it from the dealer.
http://shbox.com/1/1996_evap.jpg
Old Jan 19, 2008 | 11:10 AM
ssbowtie1's Avatar
Thanks alot guys. While the pic is up, does anyone see that oil in the tb port? That port has a hose that goes into the passenger side head. What's up with the oil in there? Normal?
I just found out my pcv valve setup wasn't working (big tear in the hose), so could that have been a cause?
Old Jan 19, 2008 | 01:14 PM
Yes, but some oil on occasion is normal for an engine with some miles on it.
Old Jan 19, 2008 | 01:22 PM
speed_demon24's Avatar
Normal with the stock pcv system. I capped everything off so I'm just running breathers now.
Old Jan 19, 2008 | 02:32 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I wonder what the failure rate is on the MAP wiring harness clip.
Old Jan 19, 2008 | 03:35 PM
96ZCamaro's Avatar
You can actualy just use some shrink wrap on that probly. Worth a try.
Old Jan 19, 2008 | 05:50 PM
Mikey97Z's Avatar
Yeah, mine's gone.
Old Jan 19, 2008 | 06:18 PM
guest74777's Avatar
Guest
I broke that on my car also, dealer got me one...
Old Jan 19, 2008 | 08:08 PM
Green96Z's Avatar
Same EVAP hose cracked on me, threw a code. Ordered one from the dealer and put it on, no more code. OBD2 is so sensitive
Fastbird93
Apr 9, 2016 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
rjc1629
Jan 27, 2015 10:46 AM
Jazsun
Dec 29, 2014 12:14 PM
