Is there a way to check timing?
Old Jun 17, 2006 | 08:44 PM
  #31
Dave89IROC's Avatar
Re: Is there a way to check timing?
Originally Posted by Rage
I will say my peace and then let this post die as it should have long ago. I have just installed this LT1 in a third gen. You know what this kind of swap includes (the K5 in your sig, unless thats an old-school LT1, in which case ignore this) and there could be tons of things that are wrong with it. I bought the engine from a guy who said it ran before it was pulled. I never heard it run, so I'm trying to explore the possibilities. I could have installed this opti wrong. Yes. And as I stated I will pull it and check it.
Injuneer, you know your stuff and you have helped me many a time whether you know it or not, just by reading through some of the tech articles on this board. I did not mean for this thread to go into the Opti install discussion as my last one did. I was just trying to see if there was a way I could check the timing. Im sorry if I came off as a punk to you.
and yes, It is a LT1 from a 94 Z28, EFI and all
Old Jun 18, 2006 | 05:30 AM
  #32
Mtrhds94Z's Avatar
That being said, on a regular distributor, I believe you can intstall it 180* off. Being on the intake or exhaust stroke. Is this also possible with the opti? I may be way off on this, just let me know.
No, if it's keyed correctly that's all there is to it.. it can't be installed[correctly] 180* off..
jb4xx
Feb 2, 2015 10:00 PM
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
danielbmx
Aug 27, 2002 11:11 PM
