Is there a way to check timing?
Old Jun 11, 2006 | 11:47 PM
Rage's Avatar
Heres the deal. I put an LT1 in my car (87 IROC) and I cant get the thing to run right. It ran fine before being pulled from it's donor, and while I hade it out, I replaced the OPTI and plugs wires, water pump, the usual stuff. But it seems now that my timing is way off. The car cranks starts and runs like crap for a few seconds, and then sputters to it's death. I have checked the firing order at least 5 times, it's all correct. I have checked my wiring and it appears to be right. I have tried to find any possible grounds that may not be grounded but I think I have them all(how many are there btw). I'm very desperate for answers, I miss my car alot! Please help in anyway you can. Thank you.
Old Jun 11, 2006 | 11:54 PM
WeirdRich's Avatar
Re: Is there a way to check timing?
if its an early style opti, its pretty easy to put on wrong and not really know it. If its a later style, its a lot harder. but eather way, thats probably your problem. I installed an opti wrong once a while back and it had the exact same symptoms.
Old Jun 13, 2006 | 11:03 PM
Rage's Avatar
How is it installed right then? What did you do wrong when you put it in? It's a 94 btw.
Old Jun 13, 2006 | 11:31 PM
Originally Posted by Rage
How is it installed right then? ...
Install like this.
Old Jun 14, 2006 | 10:57 AM
Rage's Avatar
Yeah, that's what I thought. All of them are keyed and would be close to impossible to install it wrong.
Old Jun 14, 2006 | 12:05 PM
That's what everyone thinks...... WRONG. It is very easy to assemble both style Opti's incorrectly. I'd say it happens in at least 10% of the installs.
Old Jun 14, 2006 | 01:28 PM
DrewHMS97SS's Avatar
its 95-97 that have the dowel pin from the cam into the opti ya?
Old Jun 14, 2006 | 02:48 PM
OBE1 95Z28's Avatar
Have you verified other contributors like fuel pressure, hot spark, fouled plugs, etc?
Old Jun 14, 2006 | 04:35 PM
Rage's Avatar
Indeed. I check fuel pressure, it is a constant 40 psi, the plugs are new. I am getting spart to all of my plugs, it just seems as if the timing is off.
Old Jun 14, 2006 | 04:58 PM
blkchevyz's Avatar
what year motor is it? did you use the factory wiring harness?
Old Jun 14, 2006 | 05:01 PM
Rage's Avatar
It's out of a 94 Z28, and yes I used the factory 94 harness. I bought the Opti Unit from O'rielly's and I bought the MSD cap and rotor.
Old Jun 14, 2006 | 05:02 PM
blkchevyz's Avatar
you are using a mass air flow sensor correct?
what did you hook the computer power wire to? make sure its getting power all the time when the ignition is on.
Old Jun 14, 2006 | 05:05 PM
Rage's Avatar
There are two power wires going to the ECM and both are hot in start and run. Yeah, I also purchased a new MAF from O'rielly's. Everything is hooke up right as far as I know, but if you guys have any suggestions, Im open to them all.
Old Jun 15, 2006 | 02:43 AM
WeirdRich's Avatar
check the opti again, what do you have to lose? its easier than you would think to screw it up.
Old Jun 15, 2006 | 02:47 AM
grandnational007's Avatar
CHECK YOUR COMPUTER!
you may need to reflash it, I had this same problem about a year ago...
the computer had kicked the bucket on mine
car would start, run for a few seconds, then sputter out and die
possibly shorted it out during engine swap
