Is there a significant power loss with a collapsed lifter?
I'm seeing a pretty significant power loss and I just found out I have a bad lifter. Just checking to make sure if this would be the cause of my power loss.
Re: Is there a significant power loss with a collapsed lifter?
wont it prevent the valves from opening or closing all the way...so i would think it would cause quite a bit of power lose.
Originally Posted by Fastbird93
I would think it would cause a power loss along with some wacky fuel readings, considering that not as much air would be entering the cylinder.
thats not good that you have comp R's and killed them. Are you running a standard XE grind or one of the higher lift versions?
Why is it bad? What does it mean?
LE2 cam.
Reason I asked why is because I've noticed a lopsided ratio of guys with Comp R lifters that go bad vs. guys with standard OEM replacement lifters that go bad.
I'm looking at a possibility of a few bad lifters myself. Just recently I've seen pictures of a guy who had a bunch with the retaining tops having broken off.
Did you use to have a XE? for some reason i thought you had a 230/236 at least at one point. I was saying thats not good that you collapsed a Comp R lifter because i just had my intake off replacing my OEM lifters with Comp R's and i never want to have to replace lifters again. I thought these lifters were suppose to be indestrucible.
Yes I used to have an XE 230/236 but switched to an LE2.
