Is there no aftermarket style intakes for the LT1-4
Old Dec 17, 2005 | 11:44 PM
JACKBLACK's Avatar
I can't find anything for a LT1/4 intakes.
I did find a carb intake convertion
What are my options to stay EFI. Is stock
pretty much the only Intake available??
Old Dec 17, 2005 | 11:49 PM
camaroKid223's Avatar
Re: Is there no aftermarket style intakes for the LT1-4
a few people have cut their stock intakes to make them airgaps....
Old Dec 17, 2005 | 11:53 PM
amean94ta's Avatar
pretty much unless you going low9's and beyond stick with your intake you will gain very little the intakes are great for 800 hp and below
Old Dec 18, 2005 | 12:26 AM
HardcoreRM125's Avatar
Some of the custom made ones were pretty beastly though. If your that serious about an intake, see if someone can fab you one up. Or a way to convert some of the regular SBC ones to fit an LT1, then get it hogged out.
Bret designed one for somebody a while back. It was pretty expensive I think, but on a cammed & headed motor I think they predicted it to make like a 30 horsepower gain or something insane like that. The stock intake design is OK. It gets the job done, but theres alot to be improved on as well. I could be wrong on the horsepower gain, but I remember htem saying it should have made a very noticable gain across the board.
Old Dec 18, 2005 | 12:31 AM
amean94ta's Avatar
i call bull cause a port matched lt1 intake or a lt4 with raised roof will support the hp level most of you guys go to once i hit low 9's i will switch for a hogan but for now it wont get me nowhere
Old Dec 18, 2005 | 12:47 AM
Black Cloud's Avatar
I've allready switched to a good carb.But I want a single plane intake and can't afford Hogans bucks.
I'm not going to let these LS1s kick my ***.
My car is drag only
Old Dec 18, 2005 | 01:19 AM
Call Bull ****.
I know guy that races in the Modified class at a local circle track. The motor makes 300+ HP running through a 390CFM, 2BBL carb, with restictor plate.
Just cause an lT1 intake that is port matched supports up to 800HP, doesnt mean its optimal. His 390 CFM, 2 BBL Carb handles jsut fine. He rips around that track. But its not optimal. Just cause it works doesnt mean it is perfect. The LT1 intake leaves alot to be desired. Im not saying its a bad intake, actually, its a pretty good design for what it was inteded to be used as. Just not optimal for power.
Old Dec 18, 2005 | 01:31 AM
amean94ta's Avatar
ok then whatever you two guys go buy 1k intakes for your bolton cars and have a nice day
Old Dec 18, 2005 | 01:34 AM
amean94ta's Avatar
My car is drag only
i dont have the ls1 problem anymore atleast the ones around here
I drove mine 400 miles last year so its pretty much drag only also
Old Dec 18, 2005 | 01:38 AM
1 Nasty Bird's Avatar
With the combo im looking at building 210 AFRs heavily ported and possibly a solid roller(would like to stay hydraulic roller), on a 383/396, even a ported LT4 is gonna hold it back quite a bit.
Old Dec 18, 2005 | 02:23 AM
Originally Posted by HardcoreRM125
Call Bull ****.
Who are you calling out and what the hell do you mean?
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
maybe2fast
Mar 26, 2015 08:34 AM
LT14LIFE
Feb 9, 2015 09:35 PM
sean48072
Jul 26, 2002 04:32 AM
