Is there a gasket b/t CSI water pump and water pump>
Old May 6, 2005 | 07:32 PM
Beyonce Knowles's Avatar
Like it says, is there a gasket you put between the CSI water pump and your stock pump, where the fron cover used to go? If not, should I use some RTV on there or something or just put in on there dry?
Old May 6, 2005 | 07:34 PM
sc1twntrbo's Avatar
Re: Is there a gasket b/t CSI water pump and water pump>
the onluy gasket used is a big rubber O ring thats atached to the unit
Old May 6, 2005 | 07:38 PM
Do you mean attached to the CSI pump as it comes out of the box?
Old May 6, 2005 | 10:20 PM
Blownbird355's Avatar
Yeah should go b/t pump housing and electric motor. Should come with one.
Old May 6, 2005 | 10:44 PM
Cmr0z28's Avatar
Yep...there's a tiny o-ring gasket already on the pump.
Magenta_Hearts
Mar 29, 2017 08:54 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
