Is there a formula for finding seat pressure?
Old Mar 29, 2003 | 03:19 PM
atljar's Avatar
Diameter: 1.460 in.
Pressure at 1.850 installed height: 155 lbs.
Pressure at 1.150 open height: 450 lbs.
Coil Bind at: 1.085 in.
Material: chrome silicon steel
I would like to see the seat pressures at 1.90, and 1.95 ? Any neat trick or educated guess?
EDIT: These are k-motion k-800 dual springs
Old Mar 30, 2003 | 03:23 PM
atljar's Avatar
TTT
Old Mar 30, 2003 | 03:41 PM
OldSStroker's Avatar
Re: Is there a formula for finding seat pressure?
Originally posted by atljar
Diameter: 1.460 in.
Find the spring rate: (450-155) / (1.850-1.150) = (295)/(.700)=421 lb/in
Find the difference in installed height: 1.900-1.850 = .050 inches
Calculate load change for .050 travel : .050 in. * 421 lb/in = 21 lb, so seat load @ 1.900 = 155 - 21 or 134 lb.
Your turn: what do you get for 1.95 installed height, altjar?
Old Mar 30, 2003 | 08:50 PM
atljar's Avatar
So for 1.95 it would be 42.1 lbs less, so 113. Thanks!
Old Mar 31, 2003 | 07:14 AM
Roadie
Feb 16, 2015 10:34 AM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
