Is there anything on the f-body that's problem free
Old May 12, 2004 | 01:09 AM
  #46
disco192's Avatar
Yup, i have a stretched visor strap too.
I dont think the SES light will ever burn out.
Headlights pointed STRAIGHT down, have to drive with brights.
I havent had any break issues in the calipers (power breaks dont like the cc306).
My shifter is still goin strong.
Havent had any issues with my dash.
Thats all i can think of.
-Stu
Old May 12, 2004 | 02:02 AM
  #47
crAzy95z28's Avatar
well when i open my driver side door, its goes POP, POP then when i close it it POPS once ....
sooo annoying....what else do i have wrong in ym car..o in the rear passenger seats the lil clip hanger so you can hang clothes on or w/e on the passenger side one it wont stay popped in, its all worn out, and when it rains my rear hatch leaks, and water gets all stuck in the bottom of my hatch, need to replace weather stripping i guess....driver side mirror needs to be repainted...other than that i think everything else is fine with my car!!!
lemme think really hard right fast....................still cant figure out what drains my car battery, after a few days....oo on the outside of the car on the rear hatch, you know the lil CORNER things ( guessing weather strips or something) but they are in the shape of a GUN alsmot and they clip on the rear hatch window, only 2 of them..well im missing one and they always seem to comew off very easily.....then on my driver side window switch panel, i had to replace the screw that screws in the door with a bigger screw cause the door got stripped out!!
thats it i belive...
ill let you knwo for some others
randy
Old May 12, 2004 | 02:03 AM
  #48
Xride's Avatar
I dont have anything on mine thats broken, needs replacing, or doesnt work.
but what do you expect with less then 20k on the clock.
Old May 12, 2004 | 02:21 AM
  #49
TannerMcI's Avatar
My dirty floor mats work fine they cover up my very new looking floorbord. And yet I still have them in there.
Old May 12, 2004 | 02:56 AM
  #50
TenaciousZ's Avatar
just you wait, bwahahaha
Old May 12, 2004 | 10:49 AM
  #51
redcamaroz28's Avatar
There must be something about the straps on the sunvisors, mine is stretched too. It's tucked up into the mirror. I'm thinking about just cutting it off, cause who uses them anyways.
Got more: floor-boards (haven't fallen through yet ), bumpers (haven't flown off yet ), speedometer, tach, gas gauge (although it tends to drop really fast for some reason; must have to do with the working gas pedal ), odometer, air-bags (haven't deployed), A/C, Fuse box, flap in the trunk, trunk itself.
Later
CrazyZ
Old May 12, 2004 | 11:52 AM
  #52
96speed's Avatar
Thumbs up
Originally posted by IllusionalTA
My SES light is still going strong..
Ryan
Old May 12, 2004 | 12:18 PM
  #53
CamaroBoy96Z28's Avatar
As is mine, still going strong after being on for almost a year straight. Only needs to hold up until january when I get my dyno tune.
Old May 12, 2004 | 12:43 PM
  #54
Heatmaker's Avatar
Advanced Member
Well now..... lets see
Problems...
Dome light
Cigarette lighter
A/C
Low coolant light
My Window fell out yesterday
Busted QA-1
Lost rear Sway brackets
Oil leaking from heads
Rag joint
Tie rods/ball joints
Glove Box...
Fuse Cover...
wait I'm not done yet...and neither is my wallet....
Old May 12, 2004 | 02:02 PM
  #55
Red96Lt1's Avatar
Problems...
Dome light
Cigarette lighter
A/C
Low coolant light
Busted QA-1
Rag joint
Glove Box...
Fuse Cover...
Doh! That's gotta suck.
Old May 12, 2004 | 03:25 PM
  #56
lantern's97Z's Avatar
Well let's face it guys all cars break. I don't care if it's a kia or a F1 car. Were just a bunch of poor bastards that can't afford to have some else fix our problems. So anyone got a match
Old May 12, 2004 | 04:45 PM
  #57
Heatmaker's Avatar
Advanced Member
I've just coem to realize...that atleast all my problems are because of the Suspension on the car...it's a rough ride...and crap vibrates out of place. As long as Everything works properly when I slam the pedal down... I'm satisfied.
Old May 12, 2004 | 05:05 PM
  #58
TobyZ28's Avatar
randy
For your rear hatch, check the wire that goes from the inside of the trunk to the 3rd rear brake light! Found that the wire wasn't secured properly and was kinda flopping over the stripping when the trunk was closed. Might fix your leak
Old May 12, 2004 | 05:09 PM
  #59
crAzy95z28's Avatar
ill check into that...thanks for the response, also i mean it leaks big time like the whole floor is wet with water!!!
sometiems thought about cutting awhole in it so it will leak out...
randy
Old May 12, 2004 | 05:15 PM
  #60
TobyZ28's Avatar
That sounds like it could be something else.. IF I park facing downward on a hill, only then does water pool enough in the area of that wire to cause leakage. If you park level it shouldn't really happen....
