Is there any way to...
Old Dec 1, 2003 | 12:51 PM
Camaroz28lt1383's Avatar
Is there anyway to change the rear seal on the engine without pulling the motor. I believe it is leaking. I have a 94 z28, 383 A4, I really dont want to pull then engine, but Im guessing I might have to. Also it seems almost im possible to me, how do you just drop the trans on an a4 car with out pulling the motor, because bolt access looks limited? Thanks for the help.
Old Dec 1, 2003 | 04:02 PM
I have not personally done it, but am told that you can change the rear main with engine in car. Pan does not have to be dropped. Tranny has to come out, though. The top tranny to engine bolts can be reached with several long extensions and the back of the tranny lowered.
Old Dec 1, 2003 | 04:03 PM
Z28SORR's Avatar
Yes, it can be done but no one said it would be easy! As for the trans, it helps if you have the right tools. A 36" extention and flex a socket usually works for me.
Old Dec 1, 2003 | 04:21 PM
97WS6SCharged's Avatar
Yeah, you can change the rear main with the engine in the car, but as stated, you will have to drop the trans.
Old Dec 1, 2003 | 04:34 PM
Heatmaker's Avatar
Advanced Member
Pull the motor to change out the seal is kind of extreme.
Just slide the tranny out. Annoying but cheaper to do.
Noct
May 26, 2016 10:26 AM
lankie_25
Jun 30, 2005 07:52 PM
