Are there any affordable valvesprings that will hold up to the hotcam?
Old Feb 17, 2006 | 07:06 PM
KeVMaN's Avatar
I've been looking around and haven't really found anything under $200. Am I just going to have to spend this much or are there cheaper springs out there that will still hold the .525 lift? Thanks
Old Feb 17, 2006 | 07:13 PM
Demon's Camaro's Avatar
Re: Are there any affordable valvesprings that will hold up to the hotcam?
k motion k800's are like 90 in jegs.
Old Feb 17, 2006 | 07:19 PM
blazzinbird's Avatar
that may be to much spring for the hotcam
Old Feb 17, 2006 | 07:21 PM
KeVMaN's Avatar
Will they fit without machining?
What would be the consequences of having "too much spring" ? Extra drag on the valvetrain?
Old Feb 17, 2006 | 07:22 PM
they would be to stiff i belive
Old Feb 17, 2006 | 07:41 PM
Well I dont know I was just going off what I have seen others use on their setups. Im not good at all when it comes to the valvetrain. Sorry if it will not work and I got your hopes up.
Old Feb 17, 2006 | 07:43 PM
KeVMaN's Avatar
what springs would you reccomend?
Old Feb 17, 2006 | 07:49 PM
id think comp cams 918 springs would be fine. they are a ls1 spring but will work with no maching on the lt1 heads
Old Feb 17, 2006 | 07:54 PM
KeVMaN's Avatar
any specific place that sells them? or is it a normal thing at jegs/summit whatever? Thanks for the help BTW
Old Feb 17, 2006 | 07:56 PM
you can get them threw thunderracing.com or cmotorsports.com
there around 150 though
Old Feb 17, 2006 | 08:21 PM
KeVMaN's Avatar
Comp Cams 26918 Beehive Ovate Spring, set of 16 $179.99
are these what you're reffering to?
Old Feb 17, 2006 | 09:52 PM
turbo_Z's Avatar
Whats the matter with the LT4 springs?... they should work fine.
But if you want something a little stronger then check into the Combination Motorsports 612 spring for LT1s. The 918s referred to are WAY too much for the Hotcam.. not saying they wont do the job fine but its like putting $1000 rims on a car worth $10... theyll work great but you can find something far cheaper to do the job.
Old Feb 18, 2006 | 01:33 AM
MeanGreen97Z's Avatar
LT4 springs.... 35$ bucks a set. I ran them with no valve float or problems for over 30K miles on my 97Z!
Old Feb 18, 2006 | 01:38 AM
I ran the HOT cam with them.... forgot to add that.
Old Feb 18, 2006 | 01:51 AM
GreenDemon's Avatar
That's what I was thinking. Don't go overboard unless you have a reason. They were pretty much designed to work together, so you might as well save yourself some bucks and use them.
LT14LIFE
Nov 15, 2015 06:22 PM
PopoFormula
Oct 12, 2015 04:19 PM
CARiD
Sep 30, 2015 05:44 AM
MDZ28
11
Sep 24, 2015 09:15 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
