TH400 ? need quick answer
Old Nov 27, 2004 | 08:57 PM
BigBird383's Avatar
I know this is a completely retarded question but is the TH400 a three or four speed transmission. I've always thought it was a four speed but I was just thinking that I've never actually seen that anywhere.
Old Nov 27, 2004 | 09:09 PM
1996LT1NY's Avatar
Re: TH400 ? need quick answer
three
Old Nov 27, 2004 | 09:14 PM
BigBird383's Avatar
really?? that just blows my mind. i feel like such a retard now. so that means that it has a 1:1 third gear ratio right? so it would be at the same rpm at the same speed as a th350 with a 1:1 ratio? would a well built th350 be a better swap then for a 400-500hp application?
Old Nov 27, 2004 | 09:16 PM
Seal's Avatar
there is a 4 speed version, but its not as strong....
Old Nov 27, 2004 | 09:19 PM
1996LT1NY's Avatar
Here's a list of transmission ratios that may help. The 350 & 400 are near the bottom. First & second gears are a little different, but third is the same 1:1
http://www.prestage.com/community/Te...ssion/323.aspx
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
