TF elbow installed, got a question
Old Jul 13, 2005 | 07:16 PM
warbird27's Avatar
i just installed it and i was wondering if it is alright if the tube for the optispark is not connected to the elbow? i didnt want to drill a hole in my elbow so i just tucked the tube behind the cai.
Old Jul 13, 2005 | 07:26 PM
ABA383's Avatar
Re: TF elbow installed, got a question
That tube is important because it draws a slight vacuum on the opti spark as the intake air flows past the tube and helps keep it free from moisture...Its the "vent" in your system.
--Alan
Old Jul 13, 2005 | 07:55 PM
warbird27's Avatar
so its not alright for it to be pulling air from the engine bay?
Old Jul 13, 2005 | 08:32 PM
ABA383's Avatar
It needs air to be drawn across the tube like from your intake airstream to be effective. I would figure out a way to use it, either farther downstream in the plastic of your CAI (if its plastic) or drill a small hole and use a grommet or small piece of rubber hose to use as a grommet and connect your vent tube.
--Alan
Old Jul 13, 2005 | 08:41 PM
ZMAN Z28's Avatar
I drilled a small hole in the rubber tube that was supplied with the TF elbow. Works like a champ.
ZMAN
Old Jul 13, 2005 | 08:48 PM
trans9_5am's Avatar
ZMAN
YES. This is the way you want to do it. The hole needs to be drilled AFTER the maf because the air that is sucked through the opti, through the intake, needs to be "metered" by the maf. Though a small amount, the air is still pulled through the intake and aids in the calibration of your fuel mixture.
Brandon
Old Jul 14, 2005 | 02:34 AM
1racerdude's Avatar
Brandon
The tube that goes into the CAI is for filtered air to go through the opti.The other hose on the opti is the vacuum to pull the air through the opti to vent it.
It should not be left out in the open to draw unfiltered air as the opti will soon quit working.
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
formula218
Dec 2, 2014 04:27 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
